3 Replies Latest reply on Jun 5, 2012 9:21 AM by bogiesan
    No Audio When I Drag A Clip Into The Composition
      When i try to put audio into a composition it is removed and no audio comes up. It is not a RAM preview issue as there is no audio to play. When i import any clip into after effects it works fine but if i try to add it to a composition the audio is taken away and there is not even a waveform. I tried converting the audio to a .wav format but that still doesnt work. I have tried this with after effects cs6 and cs5 but the prblem is the same. I have a mid 2011 imac with an i5 processor. I have even tried using bootcamp and trying to use after effects on the windows side but i still have the same problem. Please help as this is getting frustrating and it's probably a simple issue.
