5 Replies Latest reply on Jun 5, 2012 1:55 PM by ax1e2l_b3r4a5s6s
    applescript - replace text in specific text frame
    ax1e2l_b3r4a5s6s Level 1
      Throwing another one out there to is excellent forum:
      I know how to change text in a document:
      tell application "Adobe InDesign CS5.5"
                set find text preferences to nothing
                set change text preferences to nothing
        --Search the document for the string.
                set find what of find text preferences to "SigBelowT"
        --Replace the search with what we pulled from the db
                set change to of change text preferences to theSigCopyB
        -- this is the actual search and replace command
                set myFoundItems to change text
      end tell
      I'm trying to change text only in a specific paragraph, named as a layer in my source inDesign Document:
                tell the active document
                          try
                                    set Text_Frame to the text frame "PH"
                                    set find what of find text preferences to "~" of text frame Text_Frame
                                    set change to of change text preferences to " "
                          end try
                end tell
      end tell
      I've tried several iterations similiar to this one, but I'm not hitting the right combination.
      Suggestions??
        • 1. Re: applescript - replace text in specific text frame
          Loic.Aigon Adobe Community Professional
          I don't have exact syntax at hand but paragraphs have a findGrep method. So I guess you should write something like
          tell myparagraph
              set result to find grep
          end tell
          again, teh synatx is up to you but you get the idea. Besides what do you mean by "named as a layer in my source inDesign Document"?
          Loic
          • 2. Re: applescript - replace text in specific text frame
            Hi -
            It's named as an element under on a layer of the document.
            I use that name to find elements to change fonts, etc.  Just can't find the way to limit the search and replace to that text frame using that name.
            • 3. Re: applescript - replace text in specific text frame
              headed down this path:
                        try
                                  set myDoc to active document
                                  tell myDoc
                                            tell Text_Frame
                                            end tell
                                  end tell
                        end try
              end tell
              still not working
              • 4. Re: applescript - replace text in specific text frame
                Ok, you may need to tweak this snippet a bit. Right now, it will only apply changes to so names "foo" text frames.
                          tell active document
                                    set tfs to all page items
                                    repeat with i from 1 to count of tfs
                                              set tf to item i of tfs
                                              if name of tf = "foo" then
                  change text of tf
                                              end if
                                    end repeat
                          end tell
                end tell
                Loic Aigon
                http://www.loicaigon.com
