4 Replies Latest reply on Jun 6, 2012 4:28 PM by Studio1540
    Remove applied styles with AppleScript
    Studio1540
      In QuarkXPress is was able to remove styles with:
      set style sheet of paragraphs of story 1 of current box to null
      When I try something similar in InDesign, using:
      set applied character style of characters of parent story of myFrame to "[None]"
      I get an error saying that "Adobe InDesign CS5.5 got an error: Invalid value for set propery 'applied character style'. Expected character style or string, but received "[None]".
      "[None]" is the name of a Character Style Sheet, but for some reason it looks like InDesign doesn't recognize it as such. Does anyone know how to remove the style sheets from placed text?
        • 1. Re: Remove applied styles with AppleScript
          Loic.Aigon Adobe Community Professional
          This kind of stuff always pissed me off. InDesign expected a String. Guess what ? I gave you a String !!!
          Anyway, the None character style is always in index 1 ( 0 in js ) so you may use this as a workaround :
          tell application "Adobe InDesign CS5.5"
                    set find text preferences to nothing
                    set change text preferences to nothing
                    set find what of find text preferences to "~"
                    set change to of change text preferences to " "
                    tell active document
                              set myFrame to text frame 2 --use your own reference
            name of applied character style of parent story of myFrame
                              set applied character style of parent story of myFrame to character style 1 -- character style 1 would always point to None.
                    end tell
          end tell
          Hope it helps,
          Loic
          http://www.loicaigon.com
          • 2. Re: Remove applied styles with AppleScript
            Studio1540 Level 1
            That's exactly how I've been feeling – pissed off!
            Thanks for the insight on indexes but now I'm getting an error saying that "object is from a different document or workspace" ...
            Here's a block of code from the script:
            if content type of myFrame is text type then
                 set x to 1
                 set paraCount to count of paragraphs of parent story of myFrame
                 set applied paragraph style of every paragraph of parent story of myFrame to "Body text rag right"
                 repeat until x > paraCount
                      set wordCount to count words of paragraph x of parent story of myFrame
                      if wordCount < 3 then
                           if wordCount = 0 then
                                delete paragraph x of parent story of myFrame
                                set paraCount to paraCount - 1
                                set x to x - 1
                           else
                                set applied paragraph style of paragraph x of parent story of myFrame to "Subhead"
                           end if
                      end if
                      set x to x + 1
                 end repeat
            end if
            Am I missing something obvious in my syntax?
            • 3. Re: Remove applied styles with AppleScript
              ottopia
              You need to get the character style [None] of the parent document that contains the story.
              Try
              set applied character style of parent story of myFrame to character style "[None]" of parent of parent story of myFrame
              • 4. Re: Remove applied styles with AppleScript
                Studio1540 Level 1
                That did the trick!
                Thanx
