I am trying to create a .chm file and everything is ready to go except that when I generate and view the file, a glossary tab that I do not want shows up.
I have tried all of the advice I have found here already: "project set up," "double click windows," etc, but when I do this, "properties" is grayed out and I cannot click on it, therefore I cannot easily disable the glossary. Is there another workaround, or something I may be missing? I am using the WebHelp layout, if that makes any difference.
Thanks!
If you're using the WebHelp SSL, then you're making WebHelp. not .chm's - try using the HTML Help SSL layout.
Thanks so much! I figured it out!
