1 Reply Latest reply on Jun 6, 2012 1:21 PM by [Jongware]
    How to change keyboard shortcut for zoom in
    HilmarGud Level 1
      For some reason I dont have a keyboard shortcut for zoom in. I can zoom out and cmd+= to get a fit view. The Zoom in says that the shortcut is cmd+= but not cmd+ +
      Can I change this or add this into keyboard shortcuts?
        • 1. Re: How to change keyboard shortcut for zoom in
          Check what it is assigned to in the keyboard shortcut editor (under "Edit" menu).
          To see your current set and quickly locate under which of the dozen-and-some categories "zoom" is hiding, click the Show Set button and use the local "find" command of your OS plain text editor.
          "Cmd + +" would indicate that you need to press command, then the "+" button -- the regular way of expressing that would be Cmd +Shf + =. Perhaps you *need* to use the numerical '+' on your system? (It's not required on my Mac, I can use both the '=' and numerical '+'.)
