10 Replies Latest reply on Jun 7, 2012 12:27 PM by hhhhhhhhhhhhhh5
    How to "one-click" export an image to a set of .png files with different resolutions?
    hhhhhhhhhhhhhh5 Level 1
      Is there away to "one-click" export an image to a set of .png files with different resolutions? (I need this for a set of iOS app icons).
      For example: Export a file MyAppIcon.psd into the following:
      I almost succeeded in doing this with Photoshop Actions, but can't figure out how to make the file names include the original image file name. In other words, file NewApp.psd should export to NewApp_29x29.png, not MyAppIcon_29x29.png.
      Thank you!
        • 1. Re: How to "one-click" export an image to a set of .png files with different resolutions?
          Paul Riggott Level 6
          This should do it..
          #target photoshop
          app.bringToFront();
          main();
          function main(){
          if(!documents.length) return;
          var Name = app.activeDocument.name.replace(/\.[^\.]+$/, '');
          try{
             var Path = activeDocument.path;
              }catch(e){
                  alert("Please save this file then re-run the script!");
                  return;
          var strtRulerUnits = app.preferences.rulerUnits;
          var strtTypeUnits = app.preferences.typeUnits;
          app.preferences.rulerUnits = Units.PIXELS;
          var saveFile = File(Path + "/" + Name + "_512x512.png");
          activeDocument.resizeImage(512, 512, undefined, ResampleMethod.BICUBICSHARPER);
          SavePNG(saveFile);
          var saveFile = File(Path + "/" + Name + "_114x114.png");
          activeDocument.resizeImage(114, 114, undefined, ResampleMethod.BICUBICSHARPER);
          SavePNG(saveFile);
          var saveFile = File(Path + "/" + Name + "_72x72.png");
          activeDocument.resizeImage(72, 72, undefined, ResampleMethod.BICUBICSHARPER);
          SavePNG(saveFile);
          var saveFile = File(Path + "/" + Name + "_57x57.png");
          activeDocument.resizeImage(57, 57, undefined, ResampleMethod.BICUBICSHARPER);
          SavePNG(saveFile);
          var saveFile = File(Path + "/" + Name + "_48x48.png");
          activeDocument.resizeImage(48, 48, undefined, ResampleMethod.BICUBICSHARPER);
          SavePNG(saveFile);
          var saveFile = File(Path + "/" + Name + "_29x29.png");
          activeDocument.resizeImage(29,29, undefined, ResampleMethod.BICUBICSHARPER);
          SavePNG(saveFile);
          app.preferences.rulerUnits = strtRulerUnits;
          app.activeDocument.close(SaveOptions.DONOTSAVECHANGES);
          function SavePNG(saveFile){
          var pngOpts = new ExportOptionsSaveForWeb;
          pngOpts.format = SaveDocumentType.PNG;
          pngOpts.PNG8 = false;
          pngOpts.transparency = true;
          pngOpts.interlaced = false;
          pngOpts.quality = 100;
          activeDocument.exportDocument(new File(saveFile),ExportType.SAVEFORWEB,pngOpts);
          • 2. Re: How to "one-click" export an image to a set of .png files with different resolutions?
            Paul,
            Thank you so much!!! This is amazing! It seems to work nicely. The only problem that I noticed is that the quality of each consecutive image gets worse. For example, the 29x29 image is the result of multiple resizing operations. I'm new to Photoshop scripting, but perhaps it's possible to either "cache" the original image or "undo" after each resize?
            • 3. Re: How to "one-click" export an image to a set of .png files with different resolutions?
              No problem, please try  this...
              #target photoshop
              app.bringToFront();
              main();
              function main(){
              try{
                  }catch(e){
                      return;
              snapShot();
              SavePNG(saveFile);
              revertToLastSnapshot();
              SavePNG(saveFile);
              SavePNG(saveFile);
              SavePNG(saveFile);
              SavePNG(saveFile);
              SavePNG(saveFile);
              function snapShot() {
                  var desc9 = new ActionDescriptor();
                      var ref5 = new ActionReference();
                      ref5.putClass( charIDToTypeID('SnpS') );
                  desc9.putReference( charIDToTypeID('null'), ref5 );
                      var ref6 = new ActionReference();
                      ref6.putProperty( charIDToTypeID('HstS'), charIDToTypeID('CrnH') );
                  desc9.putReference( charIDToTypeID('From'), ref6 );
                  desc9.putEnumerated( charIDToTypeID('Usng'), charIDToTypeID('HstS'), charIDToTypeID('FllD') );
                  executeAction( charIDToTypeID('Mk  '), desc9, DialogModes.NO );
              function revertToLastSnapshot() {
                 var doc = app.activeDocument;
                 var hsObj = doc.historyStates;
                 var hsLength = hsObj.length;
                 for (var i=hsLength - 1;i>-1;i--) {
                   if (hsObj[i].snapshot) {
                     doc.activeHistoryState = doc.historyStates.getByName('Snapshot ' + i);
                     break;
              • 4. Re: How to "one-click" export an image to a set of .png files with different resolutions?
                Muppet Mark Level 5
                Paul, is there a benefit to your usage of a snapshot in history here?
                • 5. Re: How to "one-click" export an image to a set of .png files with different resolutions?
                  Hi Mark, the revertToLastSnapshot function is one of X's functions that I have used since CS2, so I keep on using it
                  • 6. Re: How to "one-click" export an image to a set of .png files with different resolutions?
                    Muppet Mark Level 5
                    Ah… I would have just stored doc.activeHistoryState to a variable then set back L8R… Im sure X will have his reasons but they may be overkill for my usage… Thanks anyway…
                    • 7. Re: How to "one-click" export an image to a set of .png files with different resolutions?
                      I think (haven't tested it) that using that method if you go over the number of history states you will have a failure, but X's should still work.
                      • 8. Re: How to "one-click" export an image to a set of .png files with different resolutions?
                        Paul,
                        Thank you again, but this didn't fix the problem. Could it be that "SavePNG" is at fault? I'm including the images here.
                        • 9. Re: How to "one-click" export an image to a set of .png files with different resolutions?
                          Muppet Mark Level 5
                          That looks to me like you have a stroke layer effect? Try adding…
                          app.activeDocument.flatten();
                          before line…
                          snapShot();
