8 Replies Latest reply on Sep 11, 2017 4:16 AM by Jarda Bereza
    Blocking the refresh of photoshop
    Julien_BOLBACH Level 1
      Is there a way in javascript to block the refresh of photoshop ?
      I'm having a script that is hiding and showing layers, but as I have hundreds of them, and photoshop refreshing the interface each time I change the visibility of a layer, it gets extremly slow ...
      I'm only interested but the end result, not the in-between steps.
      If you have any idea, please let me know !
      Thanks a lot,
      Julien
        • 1. Re: Blocking the refresh of photoshop
          Chuck Uebele Adobe Community Professional & MVP
          var idsetd = charIDToTypeID( "setd" );
          var desc3 = new ActionDescriptor();
          var idnull = charIDToTypeID( "null" );
          var ref2 = new ActionReference();
          var idPrpr = charIDToTypeID( "Prpr" );
          var idPbkO = charIDToTypeID( "PbkO" );
          ref2.putProperty( idPrpr, idPbkO );
          var idcapp = charIDToTypeID( "capp" );
          var idOrdn = charIDToTypeID( "Ordn" );
          var idTrgt = charIDToTypeID( "Trgt" );
          ref2.putEnumerated( idcapp, idOrdn, idTrgt );
          desc3.putReference( idnull, ref2 );
          var idT = charIDToTypeID( "T   " );
          var desc4 = new ActionDescriptor();
          var idperformance = stringIDToTypeID( "performance" );
          var idaccelerated = stringIDToTypeID( "accelerated" );
          desc4.putEnumerated( idperformance, idperformance, idaccelerated );
          desc3.putObject( idT, idPbkO, desc4 );
          executeAction( idsetd, desc3, DialogModes.NO );
          • 2. Re: Blocking the refresh of photoshop
            SylvanLady
            I have CS6 on Win 7 64 bit and the above code gives me an error: illegal argument.
            Any help?  My scripts are running quite slow due to all of the image refreshing and I'd love to be able to block that.
            • 3. Re: Blocking the refresh of photoshop
              Michael L Hale Level 5
              Some times this forum's software strips out what it thinks are extra spaces in text. Make sure that charIDToTypeID( "T   " ) has 3 spaces inside the quotes. CharIDs must have 4 characters.
              • 4. Re: Blocking the refresh of photoshop
                SylvanLady Level 1
                Thank you.  That solved my problem.
                • 5. Re: Blocking the refresh of photoshop
                  Jarda Bereza Level 4
                  Chuck Uebele:
                  I tried this code but I didn't see a change. Isn't it turned on by default in last Photoshop versions?
                  • 6. Re: Blocking the refresh of photoshop
                    It might be. I haven't really checked but I know I used to have to put it in some of my scripts so that they would change from acceleration mode to step mode for things like manual cropping, and some other applications.
                    • 7. Re: Blocking the refresh of photoshop
                      Davide_Barranca Level 1
                      This is equivalent of setting the PlaybackOptions in the Actions panel:
                      The code it gives in the SL (cleaned) is as follows – CC2017:
                      var s2t = function (s) {
                        return app.stringIDToTypeID(s);
                        var descriptor = new ActionDescriptor();
                        var reference = new ActionReference();
                        var descriptor2 = new ActionDescriptor();
                        reference.putProperty( s2t( "property" ), s2t( "playbackOptions" ));
                        reference.putEnumerated( s2t( "application" ), s2t( "ordinal" ), s2t( "targetEnum" ));
                        descriptor.putReference( s2t( "null" ), reference );
                        descriptor2.putEnumerated( s2t( "performance" ), s2t( "performance" ), s2t( "accelerated" ));
                        descriptor.putObject( s2t( "to" ), s2t( "playbackOptions" ), descriptor2 );
                        executeAction( s2t( "set" ), descriptor, DialogModes.NO );
                      Hope this helps,
                      Davide
                      • 8. Re: Blocking the refresh of photoshop
                        Thanks David... now it makes sense.
                        So I assume that scripts in modern Photoshop are accelerated by default.
