5 Replies Latest reply on Jun 8, 2012 5:43 AM by B4stien
    Can't modify document metadata when a dialog is open
    B4stien
      Hi everyone,
      I'm getting an error : Cannot handle the request because a modal dialog or alert is active. Whenever I try to modify the document metadata and a dialog window is open.
      I've set my extension to not be interrupted by dialogs, with UserInteractionLevels.neverInteract:
      public static function run():void
          var app:com.adobe.indesign.Application = InDesign.app;
          app.scriptPreferences.userInteractionLevel = UserInteractionLevels.neverInteract;
      Nonetheless, when I try to save meta data on the document, if a dialog is open, this code fails:
      public class Metadata
         public static function itemDownloaded(document:com.adobe.indesign.Document, dataXML:XML)
            document.metadataPreferences.setProperty("http://mydomain.com", 'data', dataXML);
      Here is the place where the metadata code is invoked, it is triggered when a file has been downloaded:
      public class FileDownloader
         public function onComplete(completedFile:File):void
             var app:Application = InDesign.app;
             Metadata.itemDownloaded(app.activeDocument, downloadInfoXML());
      Is there a way to go around it? Any suggestions?
      Thanks in advance for your help.
      - Bastien
