5 Replies Latest reply on Jun 9, 2012 5:12 AM by Muppet Mark
    execute Illustrator actions
    Sashikala Balasubramanian Level 1
      I created an action to change the width of an image. I execute the action using DoScript javascript method.
      The first action Obj1 will select the whole image and second action Obj2 will open the transform panel and change the width of the image.
              app.Open("D:\LWW_Castoff\45991_09_03.eps")
              app.DoScript("Obj1", "LWW")
              While (app.ActionIsRunning)
                  Thread.Sleep(500)
              End While
              app.DoScript("Obj2", "LWW")
                  Thread.Sleep(500)
              End While
      In the above code, the second action 'Obj2' is not getting executed. Both the actions  are getting executed individually. Let me know  the problem and how  to
      execute both the actions.
      regards,
      Sashi
        • 1. Re: execute Illustrator actions
          Muppet Mark Level 5
          Im sorry I can't help with your code but the same DOM is available to AS JS & VB there is NO need for actions in any of these to do what you want… You have resize() and transform() methods… Only call on action if the DOM does not give you access…
          • 2. Re: execute Illustrator actions
            iam unable to find the methods resize and transform in JS guide. Let me know where i had to search.
            • 3. Re: execute Illustrator actions
              Muppet Mark Level 5
              What are you using to look these things up? This is pageItems as in the PDF, OMV and Jongs viewer
              Methods
              Instances
              void bringInPerspective (positionX: number, positionY: number, perspectiveGridPlane: PerspectiveGridPlaneType)
              Place art object(s)in perspective grid at spedified perspective plane and coordinate.
              ParameterTypeDescription
              positionXnumberPosition towards X direction of specified or active perspective grid plane.
              positionYnumberPosition towards Y direction of specified or active perspective grid plane.
              perspectiveGridPlanePerspectiveGridPlaneType:
              PerspectiveGridPlaneType.NOPLANE
              PerspectiveGridPlaneType.LEFTPLANE
              PerspectiveGridPlaneType.RIGHTPLANE
              PerspectiveGridPlaneType.FLOORPLANE
              Type of perspective grid plane.
              PageItem duplicate (relativeObject: Object, insertionLocation: ElementPlacement)
              Duplicate this object.
              relativeObjectObject
              insertionLocationElementPlacement
              PageItem move (relativeObject: Object, insertionLocation: ElementPlacement)
              Move the object.
              void remove ()
              Deletes this object.
              void removeAll ()
              Deletes all elements.
              void resize (scaleX: number, scaleY: number[, changePositions: bool=true][, changeFillPatterns: bool=true][, changeFillGradients: bool=true][, changeStrokePattern: bool=true][, changeLineWidths: number=100.0][, scaleAbout:Transformation=Transformation.CENTER])
              Scale art object(s)
              scaleXnumberHorizontal scaling factor expressed as a percentage (100 = 100%)
              scaleYnumberVertical scaling factor expressed as a percentage (100 = 100%)
              changePositionsboolAre art object positions and orientations effected? (default: true) (Optional)
              changeFillPatternsboolAre the fill patterns assigned to paths to be transformed? (default: true) (Optional)
              changeFillGradientsboolAre the fill gradients assigned to paths to be transformed? (default: true) (Optional)
              changeStrokePatternboolAre the stroke patterns assigned to paths to be transformed? (default: true) (Optional)
              changeLineWidthsnumberThe amount line widths are to be scaled (expressed as a percentage) (default: 100.0) (Optional)
              scaleAboutTransformation:
              Transformation.DOCUMENTORIGIN
              Transformation.TOPLEFT
              Transformation.LEFT
              Transformation.BOTTOMLEFT
              Transformation.TOP
              Transformation.TOPRIGHT
              Transformation.RIGHT
              Transformation.BOTTOMRIGHT
              The point on the art item's bounding box to which the scale is applied. (default: Transformation.CENTER) (Optional)
              void rotate (angle: number[, changePositions: bool=true][, changeFillPatterns: bool=true][, changeFillGradients: bool=true][, changeStrokePattern: bool=true][, rotateAbout: Transformation=Transformation.CENTER])
              Rotate art object(s)
              anglenumberAngle of rotation (in degrees). Rotation is performed counter-clock wise.
              rotateAboutTransformation:
              Transformation.LEFT
              Transformation.TOP
              The point on the art item's bounding box to which the rotation is applied. (default: Transformation.CENTER) (Optional)
              void transform (transformationMatrix: Matrix[, changePositions: bool=true][, changeFillPatterns: bool=true][, changeFillGradients: bool=true][, changeStrokePattern: bool=true][, changeLineWidths: number=100.0][, transformAbout:Transformation=Transformation.CENTER])
              Transform art object(s) using a transformation matrix.
              transformationMatrixMatrixThe transformation matrix to be applied to the objects.
              transformAboutTransformation:
              Transformation.LEFT
              Transformation.TOP
              The point on the art item's bounding box to which scale and rotation operations apply. (default: Transformation.CENTER) (Optional)
              void translate ([deltaX: number=0.0][, deltaY: number=0.0][, transformObjects: bool=true][, transformFillPatterns: bool=true][, transformFillGradients: bool=true][, transformStrokePattern: bool=true])
              Reposition art object(s)
              deltaXnumberHorizontal transformation. (default: 0.0) (Optional)
              deltaYnumberVertical transformation. (default: 0.0) (Optional)
              transformObjectsboolAre art object positions and orientations affected? (default: true) (Optional)
              transformFillPatternsboolAre the fill patterns assigned to paths to be transformed? (default: true) (Optional)
              transformFillGradientsboolAre the fill gradients assigned to paths to be transformed? (default: true) (Optional)
              transformStrokePatternboolAre the stroke patterns assigned to paths to be transformed? (default: true) (Optional)
              void zOrder (zOrderCmd: ZOrderMethod)
              Arranges the art relative to other art in the group or layer.
              zOrderCmdZOrderMethod:
              ZOrderMethod.BRINGTOFRONT
              ZOrderMethod.BRINGFORWARD
              ZOrderMethod.SENDBACKWARD
              ZOrderMethod.SENDTOBACK
              How to arrange the art.
              • 4. Re: execute Illustrator actions
                You had to search not in the guide (which is just a getting started guide), but in Adobe Illustrator (Your Version) Scripting Reference. For CS5, I found it on p. 114ff.
                The Help menu in the ESTK could have told you this as well.
                ... or what Muppet Mark said. (Which is the same information, by the way, as in the Scripting Reference *and* in the ESTK Help.)
                • 5. Re: execute Illustrator actions
                  Muppet Mark Level 5
                  I do like that I can c&p it here and it all look pretty… I almost look like I know what Im doing…
