Hi community.
I can't install Adobe AIR 3.2.0.2070. I'm getting the error:
"An error occurred while installing Adobe AIR. Installation may not be allowed by your administrator. Please contact your administrator."
Here is my install log:
[2012-06-07:20:30:11] Runtime Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-07:20:30:11] Commandline is:
[2012-06-07:20:30:11] Installed runtime (3.1.0.4880) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-07:20:30:24] Relaunching with elevation
[2012-06-07:20:30:24] Launching subprocess with commandline c:\users\JoseMariaLepew\appdata\local\temp\air67f7.tmp\adobe air installer.exe -ei
[2012-06-07:20:30:25] Runtime Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-07:20:30:25] Commandline is: -stdio \\.\pipe\AIR_4624_0 -ei
[2012-06-07:20:30:25] Installed runtime (3.1.0.4880) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-07:20:30:25] Starting silent runtime update. Updating runtime from version 3.1.0.4880 to version 3.2.0.2070
[2012-06-07:20:30:25] Installing msi at c:\users\JoseMariaLepew\appdata\local\temp\air67f7.tmp\setup.msi with guid {47FA2C44-D148-4DBC-AF60-B91934AA4842}
[2012-06-07:20:30:39] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2012-06-07:20:30:39] Rolling back install of c:\users\JoseMariaLepew\appdata\local\temp\air67f7.tmp\setup.msi
[2012-06-07:20:30:39] Rollback complete
[2012-06-07:20:30:39] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2012-06-07:20:30:39] Runtime Installer end with exit code 7
[2012-06-07:20:30:42] Runtime Installer end with exit code 7
[2012-06-08:09:43:06] Runtime Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-08:09:43:06] Commandline is:
[2012-06-08:09:43:06] Installed runtime (3.1.0.4880) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-08:09:43:26] Relaunching with elevation
[2012-06-08:09:43:26] Launching subprocess with commandline c:\users\JoseMariaLepew\appdata\local\temp\airf7a8.tmp\adobe air installer.exe -ei
[2012-06-08:09:43:29] Runtime Installer begin with version 3.2.0.2070 on Windows Vista x86
[2012-06-08:09:43:29] Commandline is: -stdio \\.\pipe\AIR_3668_0 -ei
[2012-06-08:09:43:29] Installed runtime (3.1.0.4880) located at c:\Program Files\Common Files\Adobe AIR
[2012-06-08:09:43:30] Starting silent runtime update. Updating runtime from version 3.1.0.4880 to version 3.2.0.2070
[2012-06-08:09:43:30] Installing msi at c:\users\JoseMariaLepew\appdata\local\temp\airf7a8.tmp\setup.msi with guid {47FA2C44-D148-4DBC-AF60-B91934AA4842}
[2012-06-08:09:43:43] Error occurred during msi install operation; beginning rollback: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2012-06-08:09:43:43] Rolling back install of c:\users\JoseMariaLepew\appdata\local\temp\airf7a8.tmp\setup.msi
[2012-06-08:09:43:43] Rollback complete
[2012-06-08:09:43:43] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="1603" errorID=0]
[2012-06-08:09:43:43] Runtime Installer end with exit code 7
[2012-06-08:09:43:50] Runtime Installer end with exit code 7
Here is my MSI log:
Error 1402. Could not open key: UNKNOWN\Installer\Products\360D32EFD43992840A8D0036C47EB9A4\SourceList\Media. System error 5. Verify that you have sufficient access to that key, or contact your support personnel.
=== Logging stopped: 08/06/2012 09:43:43 ===
=== Logging stopped: 07/06/2012 20:30:39 ===
Sorry for my English, because my native languages are Spanish and Portuguese.
Hope someone can help. Thanks.
I've been 15 days without Adobe Air.
Can someone help me please?
Sorry for the delay, Microsoft has released a utility that can help resolve installation problems. Would you mind giving this a try and let us know how it works for you? When running the Fix it, go through the uninstall process and try to remove Adobe AIR from your system. Once finished, download the latest version of AIR and install again.
Microsoft Install and Uninstall Fix It
Chris
