This content has been marked as final.
Show 1 reply
1. Re: underline sentence(s) to create a block??
P Spier Jun 8, 2012 10:20 AM (in response to lister110@hotmail.com)If you want a full rectangular block you can use a paragraph rule and adjust the indent (negative values are allowed) but you need to adjust the rule weight to match the line count for each paragraph.
Other options, again for a full rectangle block, are to use a single-cell table or an anchored text frame with a fill and some inset. Neither of these two optiions can break across a column or page, however. If it needs to break, rule above and rule below together will work.
