6 Replies Latest reply on Jun 10, 2012 8:02 AM by namedujour
    RH9 crashes when generating content
    sc-ought Level 1
      After suddenly experiencing this problem with other projects I've developed, I decided a test case was in order. I created a new WebHelp project. Then I duplicated the initial topic a few times. Then I started to generate and publish, scanning down through the settings, but leaving them unchanged. Then I clicked Save & Generate. The project-generation animation ran for a few seconds and the blue progress-bar seemed to fill up entirely. Then RH vanishes. It shuts down without any message about problems. It starts back up again without any complaints. But when I click View Primary Layout, a dialog box explains, "WebHelp output is not generated yet. Would you like to generate it?" Clicking 'yes' starts the loop all over again.
      - We've recently had our IT group roll out some increasingly severe security measures. Is there a possibility that is obstructing the process?
      - My laptop has been having problems executing Javascripts (might be linked to the first suspect). Is this a possible source of the problem?
        • 1. Re: RH9 crashes when generating content
          Jeff_Coatsworth Adobe Community Professional & MVP
          Sounds like security - check to see that you have full rights to your \!SSL!\ folder - ideally it would be located in your c:\projects\{project_name}\!SSL!\{output_type}\ folders
          • 2. Re: RH9 crashes when generating content
            sc-ought Level 1
            Thanks for the quick response.
            I checked the Properties of the folder. It's located at C:\Documents
            and Settings\ScotAHanson\Desktop\TEST\test\!SSL! for this test project.
            It shows that I've got Allow on 6 out of 7 security permissions (the 7th is
            Special Permissions, which the Admin account doesn't have either). The
            Advanced view shows me with Allow on 14 of 14 items.
            Is there any way to view a log of the generate process and see exactly
            where things are getting derailed?
            Scot Hanson
            QA  / Technical Writer
            R7 PBS Apps Team
            --- a message from the cloud ---
            • 3. Re: RH9 crashes when generating content
              Hi there
              One way to confirm if it's an issue with needing elevated rights is to have one of your IT peeps log into your machine with their elevated "God" status and try to generate. If it works fine for them and not for you...
              There's your answer!
              Helpful and Handy Links
              RoboHelp Wish Form/Bug Reporting Form
              Begin learning RoboHelp HTML 7, 8 or 9 within the day!
              Adobe Certified RoboHelp HTML Training
              SorcerStone Blog
              RoboHelp eBooks
              • 4. Re: RH9 crashes when generating content
                sc-ought Level 1
                That's a great troubleshooting idea. On Monday, I'll try to find someone to
                test this. Thanks!
                Scot Hanson
                R7 PBS Apps Team
                • 5. Re: RH9 crashes when generating content
                  FYI - just because the default location for projects is in that long convoluted path to My RoboHelp Projects - best practices dictate using c:\projects\[individual_project_names]\ as a structure. Shorter is always better in the RH world ;>)
                  • 6. Re: RH9 crashes when generating content
                    namedujour Level 1
                    This is probably not the reason in this instance - especially with the security you say you have now, and the way you duplicated the same file over and over - but whenever Robohelp crashes on me I can usually locate a file somewhere that has a bad character in the file name, like #, %, @ etc. Robohelp doesn't like file names (or folders in the file path) with spaces, and it doesn't like file names with odd characters. I always begin with those two things.
                    So this is probably for someone else. For that someone, the solution is to just add an underscore in place of spaces, or change the file name to remove the character. Voila.
                    There was an incident a few months back when I created an interactive calendar from one of Microsoft's templates (the kind that automatically changes the days when you change the year) and saved it to a PDF, which I uploaded as a baggage file. Things got all messed up, and I couldn't generate until I removed that file. So there could be something within a random PDF somewhere that Robohelp doesn't like, like that interactive code in the original template I used.
                    What I do when this happens is create a new project and import the HTML files from the old project one group at a time until things crash. Pull in half the files and generate, then delete them and pull in the other half of the files and generate. If one half crashes the program, you know where the file is. Cut those files in half and half again until you locate the file. Do the same thing with all of your baggage files.
                    If you never crash the new project with the old files, just replace the old project with the new one. Maybe something buried deep within the original project got corrupt, so it's more efficient to just begin anew, rather than keep looking.
