1 Reply Latest reply on Jun 10, 2012 7:55 AM by the_wine_snob
    Pre Elem 8.0 Crashes Every Time I Open Existing or Create New Project
    ckjohnston
      I am a novice user of Adobe Premiere Elements 8.01
      HP Pavilion Elite
      Running Windows 7 Home Premium Edition (64 bit), Service Pack 1
      8.0 GB physical memory
      1 TB internal drive
      2 TB external drive
      500 GB external drive
      Video Card ATI Radeon HD 5570
      Until recently I was having no problems using PE 8.0.  Then several issues began.
      PE started crashing anytime I would access the organizer.
      When trying to import any .avi file longer than 40 minutes from my computer's hard drive, PE would hang and not complete the "conforming" operation.  I could no longer use PE until I deleted the media causing the issue and restarted the application.  As long as I worked with shorter duration .avi files, I had no problems.
      This morning I attempted to import 6 .avi files from my computer's hard drive.  The largest file was 789kb.  As the conforming operation was in progress on the first file, the application crashed.  Now if I open any existing project or try to create a new project the application crashes.  In other words I cannot use the application at all.
      My first inclination is to uninstall/reinstall PE 8.0 but since the application will not stay up, I cannot disable the serial number so that I'll be able to reactivate the product when I reinstall it.  Would a reinstall even be likely to correct the problem?
      How should I proceed?
