3 Replies Latest reply on Feb 25, 2013 11:52 AM by david_k
    IDCS5 Applescript
    JADarnell Level 1
      Hi All:
      I have this snippet in my Image Box Library:
      set mygraphic to make rectangle
      tell mygraphic
        --  Removed a bunch of "sets" to make snippet simpler.
      my DebugMsg("applying rotation--creating rotation matrix; RuleAngle is " & RuleAngle as string)
      --  Crashes at this statement.
      set myRotateMatrix to make transformation matrix with properties {counterclockwise rotation angle:29}
      my DebugMsg("Just made matrix.  About to apply transform.")
      transform in pasteboard coordinates from center anchor with matrix myRotateMatrix
      When I attempt to make the transformation matrix, the script crashes.  I know this because the DebugMsg handler throws up a display dialog with the message contained as an argument.  I see the "applying rotation..." dialog, but I never see the "Just made matrix..." dialog.
      The above code is modeled after a snippet I found in the InDesign CS5 Scripting Guide_AS on pages 69 and 70:
      --Rotate a rectangle "myRectangle" around its center point.
      set myRotateMatrix to make transformation matrix with properties {counterclockwise rotation angle:27}
      transform myRectangle in pasteboard coordinates from center anchor with matrix myRotateMatrix
      So I am at a loss to explain why my code does not work.
      Can anyone help here?
      R,
      John
        • 1. Re: IDCS5 Applescript
          Muppet Mark Level 5
          Do you really need to use the matrix transformations? That is the red pill… on the other hand the blue pill…
          tell application "Adobe InDesign CS5"
            activate
                    tell the active document
                              set myrectangle to make new rectangle
                              set absolute rotation angle of myrectangle to 29
                    end tell
          end tell
          • 2. Re: IDCS5 Applescript
            -hans- Level 4
            hi,
            parent (specifier, r/o) : The parent of the transformation matrix (a application).
            so remove
            from the myGraphic-tell-block.
            Example:
            tell application "Adobe InDesign CS5.5"
                tell (item 1 of selection)
                end tell
            end tell
            Hope it'll be of some help
            Hans-Gerd Claßen
            • 3. Re: IDCS5 Applescript
              david_k Level 1
              Maybe I can get a response to this....
              on your rotation here, using the
              how do you specify around what anchor point you want that rotation to occur.
              david
