1 Reply Latest reply on Jun 13, 2012 5:47 AM by rawhedrawhed
    sampleLinear doesn't work when scaling outCoord using ByteArray or Vector.<Number>
    rawhedrawhed Level 1
      I think I've found a bug in Pixel Bender that's so far been missed.
      If you want to upsample a buffer using a ShaderJob and ByteArray/Vector.<Number> it doesn't work with sampleLinear, only sampleNearest.  Using sampleLinear it returns a buffer with mostly black pixels but with every 2nd pixel (for upsampling to a double sized buffer) written to.  So basically it looks like it's upsampling but only writing to some of the target pixels...
      Btw, I'm talking about in Flash here.   And I need to use ByteArray/Vector.<Number> instead of BitmapData as I need to process 32-bit data.
      Strangely it works in the PB toolkit in all of the modes (GPU, CPU, Flash).
      Am I doing something wrong or is this a known issue?
      Here's my sample code:
      package
                import flash.display.Bitmap;
                import flash.display.BitmapData;
                import flash.display.Shader;
                import flash.display.ShaderJob;
                import flash.display.ShaderPrecision;
                import flash.display.Sprite;
                import flash.display.StageQuality;
                import flash.geom.Vector3D;
                import flash.utils.ByteArray;
                import flash.utils.Endian;
                import flash.utils.Timer;
                public class Test_Upscale extends Sprite
                          [Embed ( source = "../data/embed/pixelbender/bilinearresample.pbj", mimeType = "application/octet-stream" ) ]
                          private var BilinearScalingKernel:Class;
                          public function Test_Upscale()
                                    const srcWidth:int = 256;
                                    const srcHeight:int = 256;
                                    const dstWidth:int = 256;
                                    const dstHeight:int = 256;
                                    this.stage.quality = StageQuality.BEST;
                                    // Create noise input buffer
                                    var input:ByteArray = new ByteArray();
                                    input.endian = Endian.LITTLE_ENDIAN;
                                    input.length = srcWidth * srcHeight * 4 * 4;
                                    for (var i:int = 0; i < srcWidth*srcHeight; i++)
                                              var val:int = Math.random() * 255.0;
                                              input.writeFloat(val);
                                              input.writeFloat(255.0);
                                    input.position = 0;
                                    // Create output buffer
                                    var output:ByteArray = new ByteArray();
                                    output.endian = Endian.LITTLE_ENDIAN;
                                    output.length = dstWidth * dstHeight * 4 * 4;
                                    // Resample
                                    Resample(input, srcWidth, srcHeight, dstWidth, dstHeight, output);
                                    // Display as a bitmap
                                    this.addChild(new Bitmap(ToBitmap(dstWidth, dstHeight, output) ));
                          private static function ToBitmap(width:int, height:int, data:ByteArray):BitmapData
                                    data.position = 0;
                                    var bmp:BitmapData = new BitmapData(width, height, false);
                                    var idx:int = 0;
                                    for (var j:int = 0; j < height; j++)
                                              for (var i:int = 0; i < width; i++)
                                                        var r:int = data.readFloat() as int;
                                                        var g:int = data.readFloat() as int;
                                                        var b:int = data.readFloat() as int;
                                                        data.readFloat();
                                                        var c:int = r + (g << 8) + (b << 16);
                                                        bmp.setPixel(i, j, c);
                                                        idx++;
                                    return bmp;
                          public function Resample(src:ByteArray, srcWidth:int, srcHeight:int, dstWidth:int, dstHeight:int, dst:ByteArray):void
                                    // create and configure a Shader object
                                    var shader:Shader = new Shader();
                                    shader.precisionHint =ShaderPrecision.FULL;
                                    shader.byteCode = new BilinearScalingKernel();
                                    shader.data.src.input = src;
                                    shader.data.src.width = srcWidth;
                                    shader.data.src.height = srcHeight;
                                    shader.data.scaley.value = [0.5];
                                    var job:ShaderJob = new ShaderJob(shader, dst, dstWidth, dstHeight);
                                    job.start(true); // true flag runs the job synchronously.
      <languageVersion : 1.0;>
      kernel BilinearResample
      <   namespace : "com.test.pixelbender";
          vendor : "me";
          version : 1;
          description : "bilinear";
          input image4 src;
          output pixel4 dst;
          parameter float scaley;
          void
          evaluatePixel()
              dst = sampleLinear(src, outCoord() * float2(scaley, scaley)); // bilinear scaling
