This content has been marked as final.
Show 2 replies
1. Re: PDF file association changes to use Acrobat after Acrobat installed
Dpakch Jun 12, 2012 2:03 AM (in response to simbur999)Hi Simon,
Try please this.
Msiexec /i AcroPro.msi IW_DEFAULT_VERB=Read TRANSFORMS=Acropro.mst /qb
This should work.
Regards,
2. Re: PDF file association changes to use Acrobat after Acrobat installed
simbur999 Jun 12, 2012 5:47 PM (in response to Dpakch)Hi,
That has done the trick, thanks! I found yesterday I could also use LEAVE_PDFOWNERSHIP=YES on the command line to achieve the result, however we wanted to add to the Property table of the MST. In the case of LEAVE_PDFOWNERSHIP=YES this did not seem to work, but with IW_DEFAULT_VERB=Read it is working well.
Thanks again,
Simon
