6 Replies Latest reply on Jun 2, 2018 2:30 PM by aririmtz
    Pattern overlay lost when converting to editable text?
    amigotube
      Hey everyone.
      I'm using CS5, PC.
      I'm facing an issue I never faced before and I can't find a relevant answer for CS5. I did see an answer that is probably correct for CS3, but I hope its solves by now.
      Try 1.
      I imported a PSD as composition with merge layer styles.
      I then go to a text layer, which I want to convert to an editable text layer. When I open the properties, no layer styles appear. (because I chose mergerd layer styles composition..)
      The original PSD in photoshop has only a pattern overlay.
      When I convert it to editable text, the pattern overlay disappears.
      Try 2.
      same importing settings.. go to the text layer...
      Right click ->layer style -> convert to editable layer styles - - - > Patter overlay + Blending options appear in layers properties.
      Second Right click -> convert to editable text - - - > pattern overlay disappears.
      Try 3.
      I imported a PSD as composition with editable layer styles.
      I then go to a text layer, which I want to convert to an editable text layer. When I open the properties, 'Layer style' appears. can toggle on/off.
      But -  'Layer style' still appears in the properties, and it's on. But now when I toggle on/off, nothing changes.. Pattern is gone..
      Conclusion:
      From this I get to the conclusion, that I cannot convert a text layer which has a pattern overlay into editable text, and retain the pattern
      I hope I'm wrong, and there is a way to retain the pattern.
      Please let me know if you have a solution, or if you know for sure that my conclusion is correct..
      Thanks is advanced!
