6 Replies Latest reply on Feb 11, 2008 4:27 PM by Dan Bracuk
    Error Executing Database Query
      Hope someone might have an answer for this. I am trying to help out a friend that I wrote some CF for a while back but now they are moving to a new server and SQL server configuration. I am not sure of the specifics so if you need more to answer this question I can ask him and get you more information.
      Here is the error message:
      The following information is meant for the website developer for debugging purposes.
      Error Occurred While Processing Request
      Error Executing Database Query.
      [Macromedia][SQLServer JDBC Driver][SQLServer]The multi-part identifier "System.Web.HttpCookie" could not be bound.
      Enable Robust Exception Information to provide greater detail about the source of errors. In the Administrator, click Debugging & Logging > Debugging Settings, and select the Robust Exception Information option.
      Check the ColdFusion documentation to verify that you are using the correct syntax.
      Search the Knowledge Base to find a solution to your problem.
      Browser Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 2.0.50727; .NET CLR 1.1.4322; .NET CLR 1.0.3705; InfoPath.2; .NET CLR 3.0.04506.648; .NET CLR 3.5.21022)
      Remote Address
      Date/Time 11-Feb-08 08:57 AM
      Any help would be greatly appreciated!
