1. Re: Cannot find default printer - FM10 Win7
Jeff_Coatsworth Jun 12, 2012 2:35 PM (in response to lionnitiu)The Adobe PDF virtual printer instance should be your default printer within FM (use the free SetPrint plug-in to make this happen). That way you can keep your "real" printers as the default outside of FM. Is your instance of Acrobat Distiller working correctly? I would suspect that it's not - that may be why FM is complaining.
2. Re: Cannot find default printer - FM10 Win7
lionnitiu Jun 12, 2012 2:40 PM (in response to Jeff_Coatsworth)Hi Jeff, thanks for your response, although I don't have the technical expertise to understand it completely. But I did find an old message that suggested I change some settings in the printer properties. When I tried to do that, I got a dialog box that said "The "Adobe PDF Converter' printer driver is not installed on this computer...Do you want to install the driver now?"
So I installed the driver and restarted Frame... voila! (so far!) It seems to work. Keeping my fingers crossed.
Lygia
3. Re: Cannot find default printer - FM10 Win7
Mike Wickham Jun 12, 2012 3:35 PM (in response to lionnitiu)I've seen that same error a couple of times when loading FrameMaker. As
I recall, a reboot fixed the glitch.
4. Re: Cannot find default printer - FM10 Win7
CrazyB_LV Oct 29, 2014 11:10 AM (in response to lionnitiu)I am using FM10 in Windows 8 (I occasionally get this error whenever adobe products are updated on my machine)
If you work in a more controlled environment (Federal Subcontractor with administrative controls everywhere), I contact my IT department , or if you have the administrator rights, perform the following steps:
- Launch command prompt as administrator.
- Type “appwiz.cpl” press enter
- Right mouse click on Adobe Acrobat Pro and select change
- Select repair and click next.
- If necessary enter administrative credentials when requested.
- Reboot workstation
