1 Reply Latest reply on Jun 14, 2012 5:49 PM by Sato
    Illustrator CS5 (.ai) >> Flash Pro CS(5/6) >> Flex4 internal error occurs
    Sato
      Hi, I'm begginer in Flash-Flex env development.
      pass through the data symbol drawn in Adobe Illustrator CS5 Converted to components in Flash Pro CS6,
      the swc file compiled with Flash Builder 4.6 Flex, Build an internal error occurs.
      Not all files to error, Occurs in some files.
      The fact that the file is not found error was passed to AbcCompiler is Why do not contain data when turned into swc in Flash Pro?
      I'm looking for information from people who were able to resolve the situation the same way.
      error log is as follows:
      !SESSION 2012-06-12 20:02:55.172 -----------------------------------------------
      eclipse.buildId=I20100608-0911
      java.version=1.6.0_16
      java.vendor=Sun Microsystems Inc.
      BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=ja_JP
      Command-line arguments:  -os win32 -ws win32 -arch x86
      This is a continuation of log file C:\Users\User\Adobe Flash Builder 4.6\.metadata\.bak_0.log
      Created Time: 2012-06-12 23:26:39.448
      !ENTRY com.adobe.flexbuilder.project 4 43 2012-06-12 23:26:39.450
      !MESSAGE Uncaught exception in compiler
      !STACK 0
      java.lang.NullPointerException
                at java.io.ByteArrayInputStream.<init>(Unknown Source)
                at flex2.compiler.io.InMemoryFile.getInputStream(InMemoryFile.java:97)
                at flex2.compiler.Source.getInputStream(Source.java:381)
                at flex2.compiler.abc.AbcCompiler.parse1(AbcCompiler.java:196)
                at flex2.compiler.CompilerAPI.parse1(CompilerAPI.java:2872)
                at flex2.compiler.CompilerAPI.parse1(CompilerAPI.java:2825)
                at flex2.compiler.CompilerAPI.batch2(CompilerAPI.java:457)
                at flex2.compiler.CompilerAPI.batch(CompilerAPI.java:1291)
                at flex2.compiler.CompilerAPI.compile(CompilerAPI.java:1568)
                at flex2.tools.oem.Application.compile(Application.java:1349)
                at flex2.tools.oem.Application.recompile(Application.java:1287)
                at flex2.tools.oem.Application.compile(Application.java:886)
                at flex2.tools.flexbuilder.BuilderApplication.compile(BuilderApplication .java:359)
                at com.adobe.flexbuilder.multisdk.compiler.internal.ASApplicationBuilder $MyBuilder.mybuild(ASApplicationBuilder.java:319)
                at com.adobe.flexbuilder.multisdk.compiler.internal.ASApplicationBuilder .build(ASApplicationBuilder.java:129)
                at com.adobe.flexbuilder.multisdk.compiler.internal.ASBuilder.build(ASBu ilder.java:198)
                at com.adobe.flexbuilder.multisdk.compiler.internal.ASItemBuilder.build( ASItemBuilder.java:70)
                at com.adobe.flexbuilder.project.compiler.internal.FlexProjectBuilder.bu ildItem(FlexProjectBuilder.java:607)
                at com.adobe.flexbuilder.project.compiler.internal.FlexProjectBuilder.bu ild(FlexProjectBuilder.java:382)
                at com.adobe.flexbuilder.project.compiler.internal.FlexIncrementalBuilde r.build(FlexIncrementalBuilder.java:187)
                at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java :728)
                at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
                at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager .java:199)
                at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager .java:239)
                at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java :292)
                at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager .java:295)
                at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildMan ager.java:351)
                at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java :374)
                at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.ja va:143)
                at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:2 41)
                at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
