I'm still learning CS6, and have occasionally run into problems which I'm not yet able to get around. This is fine most of the time as I'm still learning, but occasionally I need to revert back to CS5 to produce something quickly using an existing .ai file created in CS5.
-- if I try to open the file with CS5, using the "Open with" method, CS5 doesn't appear on the list of programs I can open with.
-- if I use the "Place" command in CS5, on a CS5 file, I lose a lot of useful information such as the names I've given to all the layers. and the colors I've used to differentiate them.
-- and of course, if I try to open a CS5 file in CS5, it will open in CS6
Is there a way I can open a CS5 in CS5? Or is there a way I can add CS5 to the list of programs available that I can open with for a CS5 file? Or any other solution which I'm totally overlooking?
