Hello,
I've been using SCCM (Currently 2007 R3) to install Flash at my orginization for several years. Always setup the same way and always worked. Until now.
I create a distribution, set the install to be `msiexec /i install_flash_player_11_active_x_32bit.msi /qn`, create an advertisement, assign it to a collection, and wait.
On my two test boxes (One Windows 7 fully patches and one Windows XP fully patched) I get the same error.
Windows Installer per-user elevation of this program ("010004B5" - "Install Flash") failed for advertisement "01022398".This program was started. Please check the status of this program to determine whether or not it was completed sucessfully Possible causes: The version of Windows Installer on the computer is less than version 2.0, or the setup program does not support Windows Installer per-user elevated rights installations. Possible solutions: Update the version of Windows Installer on the computer to version 2.0 or later, or contact the software vendor that supplied the install program to determine if a version of setup that supports per-user elevated rights is available.
The program does not run and Flash is not installed.
I know windows installer is fine so It has to be the msi.
Anybody else having this issue?
-eddy
Hi Eddy,
I've seen that in SCCM when the name of the msi was simply wrong.
Hasn't that changed with the new Flash version to install_flash_player_11_active_x.msi (without the _32bit)?
Hi Eddy,
I haven't seen this error before. Could you post your msi log and I'll foward this along to our installer folks to see if they have any input.
Chris
Hi Cris,
I modified my install to be `msiexec /i install_flash_player_11_active_x_32bit.msi /qn /L+* "C:\foo\flash.log"` and gave it another run.
The good news is that it made the flash.log. The bad news is that it is empty. I'm going to try again with the x and v extra logging.
I'll let you know.
-eddy
Hi Eddy,
Ouch, I totally missed that. Thanks for your help!
-eddy
