1 2 Previous Next 64 Replies Latest reply on Jun 16, 2012 2:26 AM by billiy the cat
    mts files don't work in CS6.. Why not Adobe
    DeenoDeeno
      If I drop a .mts file from my sony camera into Prem Pro, it shows video but no sound?  If I drop it into CS5.5 the sound works.
      I have downloaded an updated version of Prem Pro from Adobe today June 2012. And still it won't handle mts files?
      I can't understand why it is so hard to find a solution to this problem. two of the worlds largest companies Sony and Adobe and none of them cover the issue on their sites, Yet it's clearly a major issue?
      I have seen talk on the site of renaming files, which doesn't work and would be a pain in the rear.
      Has Any one got a solution that works?
      Please ?
        • 1. Re: mts files don't work in CS6.. Why not Adobe
          josephs51576386 Level 3
          I have the Sony HXR-NX5U and my footage off my sd card works fine in cs6 (My cams footage is .mts too). What type of audio does your mts file have?
          Mine is set as LPCM and plays the video and audio with no issues.
          • 2. Re: mts files don't work in CS6.. Why not Adobe
            shooternz Level 6
            If I drop a .mts file from my sony camera into Prem Pro.....
            Do you have the entire Source folder  (and its structure from the card ) on your local drive?
            ie. I dont undererstand dropping a file from your camera into PremPro!
            • 3. Re: mts files don't work in CS6.. Why not Adobe
              DeenoDeeno Level 1
              I kinda new to MTS files. I have a Sony HDR XR260V  how can I check what audio the mts use?  Whn I connect the camera with USB to the PC the files are just stored in a Folder with the Date as a Name.
              • 4. Re: mts files don't work in CS6.. Why not Adobe
                DeenoDeeno Level 1
                Hi Shooternz At first I just drag and drop the mts files onto a folder on my drive.  The Sony HDR XR260V has a 160 Gig internal Drive and they show up in a folder on the cameras drive, or I can import them using Sony's proprietary software, where they are stored in a folder with the .mts file and a .MTS.modd file of the same name. Now I can navigate to them with the media browser in PP but they still offer no sound?
                Now if I use almost any method in CS5.5 the movies are there and playing sound on three Audio Tracks.  Like I say I have never used .mts before but it seems heaps of people are having this problem?
                Any help would be greatly appreciated.
                • 5. Re: mts files don't work in CS6.. Why not Adobe
                  Harm Millaard Level 7
                  when they make the mistake of not copying the complete directory to harddisk and then importing with the media browser.
                  • 6. Re: mts files don't work in CS6.. Why not Adobe
                    DeenoDeeno Level 1
                    Not the Case, I have tried that.  I think you are commenting from a position of guessing, rather than having had the problem and solved it.
                    For example.
                    1.  What complete Direcory?  The files are stored on the Camera Drive in a Directory marked "Todays Date/file_name.mts"   What on earth difference can it make copying the whole folder from the Camera to the Computer..     I will answer it,   as I have tried,   NONE!
                    2. Why does it work in CS5.5 and Not CS6.  In CS5.5  I can just drag the file out of the camera direcory to any folder on my hard drive, then drag and drop it into Prem Pro CS5.5 and when it's draged on to a sequence Voala!  Sound and Video.  BY THE WAY,  THIS IS HOW IT SHOULD BE WITH ALL VIDEO  We shouldn't have to jump through loops to move a file.
                    So unless you have expereinced the problem and solved it, Please Don't assume!  This is a real issue not a simple user error.
                    • 7. Re: mts files don't work in CS6.. Why not Adobe
                      Can't replicate your problem when I copy the complete directory and import with Media Browser. Everything works OK and I'm not planning to look for ways to create havoc.
                      • 8. Re: mts files don't work in CS6.. Why not Adobe
                        DeenoDeeno Level 1
                        I don't suspect you are but again, What directory? The directory on my Camera has no unusual structure?  And again why CS6 and not CS5 ?
                        • 9. Re: mts files don't work in CS6.. Why not Adobe
                          From a Panny TM-700 these are the directories:
                          I simply copy the complete harddisk from the Panny to my harddisk and have no issue at all with CS5.5 and CS6.
                          • 10. Re: mts files don't work in CS6.. Why not Adobe
                            DeenoDeeno Level 1
                            Your using a SD Card (I'm Pretty sure)   on The Built in Hard disk of the Sony HDR XR260V I don't have to use an SD card. But there is no BDMV Directory or stream like you show here.  Camera/Date/File
                            So where you have to copy that file structure over, I don't have it.
                            The think is I think the Error lies in the CS6 Software, not the File other wise the mts files from my Camera would not work (as they do) on CS5.5 and refuse to work of CS6  I really would like to find a more conclussive answer.  The copy directory thing is worn out and does not work in my instance. But WHY ??
                            • 11. Re: mts files don't work in CS6.. Why not Adobe
                              Joe Riggs Level 1
                              Ideally you would like to have the entire directory, however, I've NEVER HAD TO HAVE the complete directory in 5.5 to get audio with .mts files. With 5.5 you could simply just "drop in" the actual .mts files and that flexibility is one of the great strengths of Premiere.  Is this a new issue with CS6?
                              • 12. Re: mts files don't work in CS6.. Why not Adobe
                                Alan Craven Level 4
                                I have just switched to CS6 and a Canon HF S30.  This produces .mts files.
                                I have no problem with them when I ingest them via the Canon Pixelas software (which ingests .cpi info files as well), nor when I simply drag and drop the required .mts files from the connected camera's internal memory to a folder on my media hard disk.
                                I also have no problems with them when I use my laptop, which has CS5 installed.
                                I realise that this does not help you, but it shows that CS6 does not have a problem with .mts files per se.  Maybe there is some oddity with the particular Sony version?
                                • 13. Re: mts files don't work in CS6.. Why not Adobe
                                  DeenoDeeno Level 1
                                  I suppose this could be another example of Corporations being difficult?  I.e Adobe trying to be awkward with Sony or Vice Versa.  But until I can find out the where the problem lies then it hard to apportion the blame.
                                  Are there different types of .mts files?
                                  [offensive language removed]
                                  • 14. Re: mts files don't work in CS6.. Why not Adobe
                                    No, the TM-700 has a 120 GB hard disk built in.
                                    • 15. Re: mts files don't work in CS6.. Why not Adobe
                                      DeenoDeeno Level 1
                                      I would hate to have to change my software over a compatibility issue. I hope Adobe can do something to correct this.  It's seems I cam drop the files into MS Movie Maker and Sony Vegas without any issues, why not CS6 ??
                                      • 16. Re: mts files don't work in CS6.. Why not Adobe
                                        jasonvp Level 3
                                        Before we go throwing our software out, can we take a breath and relax for a second?  You've got a pile of people here trying to help and you're kinda snapping at them.
                                        Can you connect your Sony to your Windows rig, open it up in the Windows File Explorer like Harm did, expand ALL directories, and take a quick window capture of that?  Post it so we can see?  Something doesn't seem right regarding how the AVCHD directory structure is laid out on your camera.  There's a very specific directory structure expected.
                                        Post it and let's go from there.
                                        jas
                                        • 17. Re: mts files don't work in CS6.. Why not Adobe
                                          Jim_Simon Level 8
                                          That seems difficult to believe.  Your camera carries the official AVCHD logo, which means it must adhere to the AVCHD specifications, which include a very specific folder structure like Harm has shown.
                                          • 18. Re: mts files don't work in CS6.. Why not Adobe
                                            Jim_Simon Level 8
                                            That has happened in the past.  Sony wasn't writing the proper headers to the file, and so PP had issues with it.  I believe that was resolved, though.
                                            • 19. Re: mts files don't work in CS6.. Why not Adobe
                                              Jakub PL
                                              hi evryone.
                                              i have got a mts files with Panasonic camera. And the sound not import to my project. what i can do to fix thix?
                                              • 20. Re: mts files don't work in CS6.. Why not Adobe
                                                Jim_Simon Level 8
                                                Upload one of the smaller files so we can test on our systems.
                                                • 21. Re: mts files don't work in CS6.. Why not Adobe
                                                  Jakub PL Level 1
                                                  ok, please simple link. https://dl.dropbox.com/u/85370462/00010.MTS
                                                  When we have got a CS5.5 all was great.
                                                  • 22. Re: mts files don't work in CS6.. Why not Adobe
                                                    Trent Happel Adobe Employee
                                                    I tried the sample file from Jakub PL and the file has audio for me on my Mac and Windows systems with Premiere Pro 6.0.1.
                                                    For those having issues with no audio with AVCHD files, could you try the following:
                                                    1) Quit Premiere. Launch Premiere again. Go to the Help menu and verify that you are activated (towards bottom, should see "Deactivate..." that signifies that you are activated).
                                                    2) Go to Preferences > Media > Media Cache Database. Click the "Clean" button. Import your file(s) again and see if you get audio now.
                                                    3) If 1 and 2 do not work, then could you please try to uninstall and then install Premiere Pro again.
                                                    I have confirmation from two people that step #3 worked for them.
                                                    Thank you.
                                                    • 23. Re: mts files don't work in CS6.. Why not Adobe
                                                      Wharkey
                                                      And I have the same problem, Panasonic SD900, when I import a mts file in PPcs6, then only video wil appears but no audio track, when I convert the mts to mp4, then I have sound and video.
                                                      • 24. Re: mts files don't work in CS6.. Why not Adobe
                                                        This file has audio for me when I import it into premiere cs6... Great spanish music by the way. I'd try to clean your cache and re-import like the post above suggested because if that isn't it and the activation part isn't the problem I dunno what else to say since it works fine for me.
                                                        • 25. Re: mts files don't work in CS6.. Why not Adobe
                                                          Nicol Simard Level 1
                                                          The file plays fine on my computer. I am not trying to say your problem doesn't exist but I can't replicate it.
                                                          • 26. Re: mts files don't work in CS6.. Why not Adobe
                                                            This is why you must copy the entire folder to your hard drive http://forums.adobe.com/thread/1015001?tstart=0
                                                            • 27. Re: mts files don't work in CS6.. Why not Adobe
                                                              For me the file worked fine even without  the folder structure. However for me personally I always copy the BDMV structure over because otherwise the clips from my SDHC card aren't joined properly.
                                                              • 28. Re: mts files don't work in CS6.. Why not Adobe
        DeenoDeeno Level 1
        Hi John T Smith
        There is some confusion for me here, the link you provide refers over and over to SD Card Structure. And if I put an SD Card into my Camera I see that Structure BUT my camera has 160GB internal drive and I don't need, or want, to use an SD Card. The problem is when I look at the cameras Hard Drive there is no such structure, just a Date Folder and the .mts file inside.
        When you import the mts file over to the PC you get the single file and one .modd file in a date folder?
        So all the talk about copying the whole file structure over doesn't and can't apply in this instance?    What then
        Thank you for you reply by the way.
        • 29. Re: mts files don't work in CS6.. Why not Adobe
        Upload a small test file using adrive or dropbox or something. Because I'd like to see if the clip has audio for me personally. One of the other people in this thread said their clip didn't have audio but when I imported it, it did indeed have audio on my specific system. Which makes me wonder if this is some sort of isolated issue, which may or may not be hard to reproduce. I'm just intrested to see if it will play on my system. Please don't misunderstand though because I for sure believe that you are experincing a issue because obviously you wouldn't keep posting if it wasn't a real problem.
        • 30. Re: mts files don't work in CS6.. Why not Adobe
        DeenoDeeno Level 1
        jas
        Jas, firstly I don’t see,  reading back the quote in your post that there was anything snapping about it? It was just the facts, I have a heap of work to do an suddenly the software I have come to trust, is useless to me, because I buy a new camera??
        I apologize if some of my replies seemed abrupt, I felt the comments were implying the problem was of my making.  I have read through dozens of forums and I see time and time again people asking this question to no avail. I can’t accept that we are all to blame.
        You guys are great on the forum, thank you.   I have a workload backing up and am tossing up between limping along in Movie Maker or going back to 5.5 and I can assure you that going back to 5.5 is frustrating after getting used to CS6.  In an effort to repair this problem, I have had to uninstall and reinstall several times and have lost all my presets, which you can imagine is frustrating, when you’re in a work groove. I hope that explain a little my frustration.
        Here is the file structure of my camera and you will see I have no option to copy the BDMV structure everyone talks about.
        • 31. Re: mts files don't work in CS6.. Why not Adobe
        DeenoDeeno Level 1
        I would but I see little point. I am not saying the clips don't have Audio. I can use the clips (with audio) in, Movie Maker, Sony Vegas and watch them back on Windows Media Player without any issues.
        I could also play Jakub's file from above and it had no file structure (just a straight mts file)  It plaid in WMP and can be edited in Windows Movie maker no problem???
        Could it be that Adobe haven't paid for the rights to import Dolby 5.1 Surround Sound into CS6 (just something I read this morning)
        • 32. Re: mts files don't work in CS6.. Why not Adobe
        If it works in cs5.5 you could just take the files and get them all stacked up in 5.5's media encoder and encode the audio only to a different audio codec then just import the new audio files into cs6 and link the clips up in cs6 if you where wanting to edit in cs6 over 5.5. I know this obivously a extra step but it wouldn't take hardly any time since you'd only being re-encoding the audio only anyways. Plus you could just stack all of them in the encoder walk away and come back a bit later and they'd all be ready when you came back.
        I realize this isn't the best solution and you have problably already thought of this and chose not to do it since it adds a extra step but I don't know what else to suggest. Sorry
        • 34. Re: mts files don't work in CS6.. Why not Adobe
        DeenoDeeno,
        Have you tried the 3 items that I listed earlier today? Premiere Pro CS6 does have support for Dolby audio in AVCHD files and many customers are seeing audio in their files. For some reason, some customers (such as yourself) and not getting audio and we believe this may be due to an something that went wrong during installation. I have spoken to a few people that have had the same issue as you and uninstall and then re-install Premiere fixed the issue for them. Here are the 3 things to try:
        #3 has been confirmed by some people to resolve this issue.
        Thank you.
        • 35. Re: mts files don't work in CS6.. Why not Adobe
        Jim_Simon Level 8
        It would appear that the camera is shooting "out-of-spec" when you use the internal drive.
        It may be wiser to use the SD card option.
        • 36. Re: mts files don't work in CS6.. Why not Adobe
        DeenoDeeno Level 1
        Trent Happel wrote:
        DeenoDeeno,
        Thank you.
        Hi Trent
        I tried step a and 2 but no good.  I will try the uninstall reinstall again a bit later but I have tried it before and it was no good, I even re downloaded from adobe to see if the package had been amended (about three days ago) but no good with that also.
        I will try a reinstall later.  Is there likely to me a update soon, I did get 6.0.1 but that didn't address the issue. Is there a was of copying some of the CS5.5 preset function to CS6 Manually?
        • 37. Re: mts files don't work in CS6.. Why not Adobe
        DeenoDeeno Level 1
        No No!  Jim, sorry but you don't buy a camera with 160GB hard drive and stick a 8 GB SD card in it to take film.
        Again I hope I don't sound abrupt but that can never be the solution.
        • 38. Re: mts files don't work in CS6.. Why not Adobe
        Jim_Simon Level 8
        Well...you also don't buy a camera that shoots non-standard video and expect it to work flawlessly.  Sometimes they work, but sometimes not.
        This appears to be a 'not'.
        • 39. Re: mts files don't work in CS6.. Why not Adobe
        DeenoDeeno,
        When you imported Jakub's .mts file in Premiere Pro CS6 on your system, did it have audio? If it did not, then it would possibly point to something going wrong with your installation of CS6.
        If you do get audio with Jakub's file (in Premiere Pro CS6), but not the files from your camera, then that sounds like something specific to your files. In that case, would it be possible to get a small sample file from your camera for us to look at?
        Thank you.
        1 2 Previous Next
