1 Reply Latest reply on Jun 15, 2012 9:49 PM by ManishNamdev
    Mobile Orientation
    ManishNamdev
      Hello friends,
      I'm working with FlashBuilder 4.6 to develop Android app.
      In the application there is a requirement of setting some values when device orientation changes. i.e. setting the values when the screen/device orientation changes from Landscape to Portrait and vice-verse.
      Although Initially my application has LandScape orientation. And this requirement is on specific view.
      I want every time when the screen/device orientation changes the values must be set there.
      I am not getting the desired result.
      Please guide me and tell me if I am at wrong in code or how can i achieve this.
      <s:View xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark" title="{data}"
      xmlns:mx="library://ns.adobe.com/flex/mx"
      viewActivate="view1_viewActivateHandler(event)"
      creationComplete="view1_creationCompleteHandler(event)">
      <fx:Script>
         <![CDATA[
      protected function view1_viewActivateHandler(event:ViewNavigatorEvent):void
          if(Accelerometer.isSupported)
      accl = new Accelerometer();
              accl.addEventListener(AccelerometerEvent.UPDATE,update);                    //accl.addEventListener(AccelerometerEvent.UPDATE,adjustImage);
      private function update(event:AccelerometerEvent):void
           this.stage.autoOrients = true;
           //in the below line I am attaching StageOrienationEvent that will adjust the
           //values.
           stage.addEventListener(StageOrientationEvent.ORIENTATION_CHANGE,adjust);
      private function adjust(event:StageOrientationEvent):void
           if(event.afterOrientation == StageOrientation.ROTATED_LEFT)
      testVal.text ="After OR is LEFT";
           else if(event.afterOrientation == StageOrientation.ROTATED_RIGHT)
      testVal.text ="After OR is RIGHT";
           else if(StageAspectRatio.LANDSCAPE)
      testVal.text ="StageAspectRatio is Landscape";
           else if(StageAspectRatio.PORTRAIT)
      testVal.text="StageAspectRatio is  Portrait";
      </fx:Script>
        • 1. Re: Mobile Orientation
          ManishNamdev Level 1
          Finally found the solution after spending two days on this.
          in update function add OrientationChanging Event in stage.addEventListner.
          protected function update(event:AccelerometerEvent):void
                this.stage.autoOrients  = true;      stage.addEventListener(StageOrientationEvent.ORIENTATION_CHANGING,adjust);
          protected function adjust(event:StageOrientationEvent):void
                switch(event.afterOrientation)
                    case StageOrientation.DEFAULT:
                    //Do Something here. The Portrait Position.
                                  break;
                    case StageOrienatation.ROTATED_LEFT:
                    //Do Something here when you rotate your phone portrait to left side.
                             break;
                    case StageOrienatation.ROTATED_RIGHT:
                    //Do something here when you rotate your phone portrait to right side.
                             break;
          Many thanks to all who viewed this question and try put their efforts for solution.
