1. Re: Why does Photoshop display colors differently from the other applications even in sRGB mode ?
charles badland Jun 14, 2012 5:16 AM (in response to yannick1976)What are you using to calibrate your monitor and create its profile?
2. Re: Why does Photoshop display colors differently from the other applications even in sRGB mode ?
yannick1976 Jun 14, 2012 5:26 AM (in response to charles badland)an eye-one display 2 device and eye one match 3 software
3. Re: Why does Photoshop display colors differently from the other applications even in sRGB mode ?
c.pfaffenbichler Jun 14, 2012 5:29 AM (in response to yannick1976)I think you have grasped the concept:
An image’s profile determines how a certain combination or RGB-values is supposed to appear and Photoshop uses the monitor profile to determine what values it needs to pass on to get that appearance or an approximation on the screen.
If you softproof with the monitor profile you are effectively circumventing Color Management and the RGB-values are desplayed directly, so to speak.
4. Re: Why does Photoshop display colors differently from the other applications even in sRGB mode ?
yannick1976 Jun 14, 2012 6:13 AM (in response to c.pfaffenbichler)Sorry I didn't get it. Actually my problem is there are things I don't understand
I thought windows was handling monitor calibration, not Photoshop.
But it appears Photoshop does something when I apply (with windows) my monitor profile. What it does and why, this I don't understand.
5. Re: Why does Photoshop display colors differently from the other applications even in sRGB mode ?
Chris Cox Jun 14, 2012 10:38 AM (in response to yannick1976)>> I thought windows was handling monitor calibration, not Photoshop.
Nope. Windows doesn't do anything to correct colors for your display. There is no global calibration.
WIndows provides the display profile to applications that are interested in using it, and loads the LUT from the profile into your video card (that does the most minimal "calibration").
It's up to the application to use the display profile correctly and convert document colors to display colors.
And right now only some professional applications and a few browsers do that (but not all browsers).
6. Re: Why does Photoshop display colors differently from the other applications even in sRGB mode ?
Noel Carboni Jun 14, 2012 1:55 PM (in response to Chris Cox)And some browsers do it wrong - for example, Internet Explorer makes the implicit assumption that your monitor is sRGB regardless of what profile you have associated with it.
-Noel
7. Re: Why does Photoshop display colors differently from the other applications even in sRGB mode ?
yannick1976 Jun 14, 2012 1:09 PM (in response to Chris Cox)Thanks for that answer.
If I understand correctly there is still a global calibration, done by the video card ? I mean I do see a global change when I apply my profile.
So even if Photoshop is doing the calibration on its own, what it does should still match what the video card does (as soon as everything is in sRGB), and using monitor sRGB proof colors shouldn't be needed, or did I miss something ?
8. Re: Why does Photoshop display colors differently from the other applications even in sRGB mode ?
gator soup Jun 14, 2012 1:25 PM (in response to yannick1976)Photoshop (CMS) reads an embedded ICC profile and CONVERTS it to the custom monitor profile for a theoretical 'true color' display -- nonmanaged apps generally only pass the RGB information straight through to the monitor unaltered
when Photoshop is configured to ignore or not use a document profile, Photoshop ASSIGNS (for all practical purposes) its Working Profile/Space and then CONVERTS it to the custom monitor profile -- if the Assigned source profile is wrong, Photoshop displays wrong, but it can easily be corrected by Assigning the correct profile
Photoshop already displays sRGB in theoretical 'true color' so View> Proof Setup: sRGB can be confusing
for me, View> Proof Setup: Monitor RGB is much more useful as an enlightening tool...
9. Re: Why does Photoshop display colors differently from the other applications even in sRGB mode ?
Noel Carboni Jun 14, 2012 1:30 PM (in response to gator soup)Gator soup, you should really try to use proper and accurate terminology.
Photoshop transforms color values from documents to devices based on the color profiles that describe the two.
Photoshop has a menu in which you can convert the color values from one document profile to another. There's some relationship between the two, but if you use the word "convert" to describe what happens to colors on the way to a monitor I suspect you'll just confuse people.
And experience has shown us that a complete understanding of color-management cannot be taught via forum posts.
-Noel
10. Re: Why does Photoshop display colors differently from the other applications even in sRGB mode ?
gator soup Jun 14, 2012 1:40 PM (in response to Noel Carboni)>> Gator soup, you should really try to use proper and accurate terminology.
Noel Carboni, good grief, for a bright guy, you seem awfully insecure...
11. Re: Why does Photoshop display colors differently from the other applications even in sRGB mode ?
Lundberg02 Jun 14, 2012 1:49 PM (in response to yannick1976)No, you don't understand correctly. Read Chris Cox answer over and over again until you know what it means.
12. Re: Why does Photoshop display colors differently from the other applications even in sRGB mode ?
Noel Carboni Jun 14, 2012 1:50 PM (in response to gator soup)I guess I should just not say anything in color-management threads. Sorry. My fault for trying to help.
-Noel
13. Re: Why does Photoshop display colors differently from the other applications even in sRGB mode ?
gator soup Jun 14, 2012 2:04 PM (in response to Noel Carboni)Noel Carboni wrote:
-Noel
suit yourself
14. Re: Why does Photoshop display colors differently from the other applications even in sRGB mode ?
yannick1976 Jun 14, 2012 3:30 PM (in response to Chris Cox)Aaah, ok, I get it now. I thought you said windows did nothing at all, when actually what you said was that what it does is very basic.
So what you say is the differences in color I see are between poor calibration and proper calibration.
Still I'm surprised the difference is so big. There might be a way to make sure this is where the difference comes from ?
15. Re: Why does Photoshop display colors differently from the other applications even in sRGB mode ?
Noel Carboni Jun 14, 2012 3:52 PM (in response to gator soup)That sounds like an invitation to continue to talk about the issue. Fair enough.
I'm not sure where you're getting "insecurity"... I am just trying to help you help others more effectively.
I invite you to re-read just the first sentence of what you wrote very carefully, putting yourself in the shoes of someone struggling with both the terminology and the concepts:
- Think about what "Photoshop (CMS)" might mean to a person who doesn't know the acronym might stand for "Color Management System" (which is I assume what you meant). Adobe themselves don't call it "CMS", they use the acronym "CMM" (Color Management Module). The term "CMS" is used in the computer industry for about a dozen different things.
- While a color profile might have been embedded in an image file before it was opened by Photoshop, Photoshop works on documents. A profile is not "embedded" in a document, it is maintained by Photoshop with the document and describes the color values in the document. If Photoshop opens a document without an embedded profile, depending on settings and user choices it might assign a profile or it might even operate on the document without color-management. Oversimplification doesn't help people when they're trying to learn new things unless it's described as such, for example, "This is a bit of an oversimplification..." or "Generally speaking..."
- Not every monitor profile is a "custom monitor profile". Quite often a standard profile (e.g., sRGB IEC61966-2.1) is associated with a monitor by the operating system as a default, or a factory profile is installed by a driver package or system update. Your use of the term "custom" is a bit ambiguous and could be read as implying the creation of a profile using a calibration and profiling device specific to the particular monitor.
- Photoshop's color management code does not convert an embedded ICC profile at all (read carefully what you wrote). As I said, it transforms color values. That was the key error in your description that prompted me to comment.
If ever there is a time to pick words carefully, it's in a color-management discussion.
-Noel
