1 Reply Latest reply on Feb 13, 2008 8:24 PM by DaOrangeMan
    Anchor in HTML
    Level 7
      Im importing an xml file that has html code inside and I display it in
      dynamic textbox with Render to HTML selected. I view the content perfectly
      but would like to add a <a href> link that point to an anchor <a> inside
      that same text. The link is active but when clicked on nothing happens.
      Can anyone help?
        • 1. Re: Anchor in HTML
          have you set your publish settings to "Flash with Named Anchors?" It is under the HTML tab of the publish settings, select the above named template.
          It puts javascript into the html doc that houses your swf. Not sure if it entirely applies to what you are doing, but it is the first step in getting anchors going.
