9 Replies Latest reply on May 27, 2013 6:46 AM by reusr1
    Dialog Participant step problem when completed with CQ Sidekick
    angerwin Level 1
      I got the problem that the dialog that is used in a Dialog participant step isn't displayed correctly when i complete the Step via the CQ Sidekick. If i complete the step from the User inbox the dialog is rendered correctly. To make it clear : if i use the CQ Sidekick to complete the Step then i can only enter the next step and a comment and not the additional fields that should be added because of the dialog.
      My first guess is that my dialog.xml isn't correct but i can't find the Problem. What is your experience with the Dialog Praticipant step?
      This is the dialog i use:
      <?xml version="1.0" encoding="UTF-8"?>
      <jcr:root xmlns:cq="http://www.day.com/jcr/cq/1.0" xmlns:jcr="http://www.jcp.org/jcr/1.0" xmlns:nt="http://www.jcp.org/jcr/nt/1.0"
          jcr:primaryType="cq:Panel">
          <items jcr:primaryType="cq:WidgetCollection">
              <title
                  jcr:primaryType="cq:Widget"
                  border="{Boolean}true"
                  collapsed="{Boolean}false"
                  collapsible="{Boolean}false"
                  fieldLabel="Bullet Points"
                  name="./listItems"
                  typeHint="String"
                  xtype="multifield">
                  <fieldConfig
                      jcr:primaryType="nt:unstructured"
                      maxLength="{Long}50"
                      minLength="{Long}1"
                      separator=""
                      xtype="textfield"/>
              </title>
          </items>
      </jcr:root>
      Thank you
