1. Re: How Do You Delete A Step with the Polygon Lasso Tool
groove25 Jun 14, 2012 9:16 AM (in response to pmsquillace)There doesn't appear to be an option for it. The standard advice seems to be to add or subtract from the selection afterward, using other bitmap tools, if needed.
This tutorial covers the Polygon Lasso tool in some depth, and has some decent tips on using zoom shortcuts and "splitting pixels"—as well as using the caps lock key to change the cursor (to better visualize where you click).
http://www.youtube.com/watch?v=VfW_SDxkTOs
Allowing the use of the delete key to move back a step (as in Photoshop) would make a good feature request, which you could submit here:
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
2. Re: How Do You Delete A Step with the Polygon Lasso Tool
pmsquillace Jun 14, 2012 11:12 AM (in response to groove25)Thanks Groove, that helped me a ton.
I aslo submitted the change to adobe, see if it sticks...
Thanks again.
paul
3. Re: How Do You Delete A Step with the Polygon Lasso Tool
Jim_Babbage Jun 14, 2012 11:39 AM (in response to pmsquillace)Another option that gives you great deal of control is to use the Pen tool instead of the Polygon lasso. Because it's a vector path, you can fine tune the outline very easily using the Pen and Subselection tools, and when you're happy with the result, choose Modify > Convert Path to Marquee. You can even opt to retain or delete the vector path in the Preferences panel.
HTH
4. Re: How Do You Delete A Step with the Polygon Lasso Tool
pmsquillace Jun 14, 2012 12:13 PM (in response to Jim_Babbage)Thanks Jim!
I did not even know this was an option. This works much better for me.
Paul
