3 Replies Latest reply on Jun 14, 2012 10:20 AM by Jeff Arola
    What is color burn layer?
    hummer777 Level 1
      I was reading one of techniques for removing blue haze from pictures.
      The initial two steps were as follows:
      1. Click on your color burn layer
      2. Select all and copy the color burn layer only to the clipboard
      I have never used "color burn layer".  So I have no idea what "color burn layer" is and how to create it.
      Please asvise me how to creaste color burn layer.
      I have photoshop CS5 (with Windows 7).
        • 1. Re: What is color burn layer?
          Jeff Arola Adobe Community Professional
          That usually means applying the color burn layer blending mode to a layer.
          Can you post a link to the tutorial?
          If it's in a book then there must be steps mentioned somewhere on how they got the color burn layer.
          • 2. Re: What is color burn layer?
            hummer777 Level 1
            It is not a tutorial.   Somebody asked the question in a photo forum.
            I now lost the original webpage but I copied the anwer as follows:
            clipboard
            Open a Hue/saturation adjustment layer but make no corrections just press OK.
            Alt click on the Hue/adjustment layers mask this will make the screen go white.
            Edit> paste... this will paste the color burn layer to the mask.
            We must reverse the mask now so press Ctrl+I or Image>Adjustment>Inverse
            Click on the adjustment part of the hue/saturation or Alt click on the mask again.
            Now reduce saturation by moving the saturation slider to the left.
            My question is how to careate color burn layer in CS5 photoshop.
            • 3. Re: What is color burn layer?
              One can only guess (at least i can only guess how the color burn layer was created) since the instructions are incomplete and we probably need to know the question.
              Could be anything from just naming a layer color burn to actually applying a color burn blending mode to a layer, then merging with another layer or any number of ways.
              There is no actual layer in photoshop called color burn.
