1 Reply Latest reply on Jun 14, 2012 11:57 PM by Gernot Hoffmann
    Finding the right HEX colour for a Pantone
    J.David.Maclean
      I'm trying to match a HEX colour to Pantone 369C. I've set my colour model in Bridge to Europe Web/Interent 2. Every time I convert the colour from Pantone to RGB the colour is way too bright. I'm not really after the exact colour match, more what looks better on the screen.
      If I start in Ai with a pantone swatch then convert to RGB everything looks good.
      If I open the Ai document in Ps it looks good.
      If I select the pantone swatch in Ps colour picker it looks wrong.
      Converting the pantone to RGB gets: 116, 175, 38 > #74af26  however it looks wrong in Dw
      I'm using the sRGB colour space [as defined by my Br settings] and I'm exporting for web without colour management. The colour conversion in both Ps and Ai work out to be roughly the same, only 1 or 2 shades different, not the radical change you get when selecting the swatch in Ps
      So my question really is, failing just tweeking the colour breakdown myself, is there some way I can get the right HEX colour to match what I see in Ai? See the attached image for example.
      Thanks in advance.
        • 1. Re: Finding the right HEX colour for a Pantone
          Gernot Hoffmann Level 3
          David,
          please compare your values ?RGB = 116 / 175 / 38 for 369C:
          http://www.fho-emden.de/~hoffmann/swatch16032005.pdf
          Lab:    60.5 / -44.2 / 60.4
          sRGB: 80 / 164 / 0
          aRGB: 112 / 163 / 38   aRGB=AdobeRGB(1998)
          Photoshop CS2:
          Lab:    61 / -45 / 61
          sRGB: 79 / 166 / 0
          aRGB: 112 / 164 / 38
          Your RGB values are nearer to aRGB (but still different), and then
          it's highly doubtful why these should be expressed by Hex-numbers,
          because Hex is used only in HTML. It cannot be expected that
          browsers will interprete these numbers correctly.
          Considering the same appearance in different applications:
          This requires
          a) a calibrated monitor
          b) correct color space settings
          c) applications which use color management (like Adobe CS#)
          Finally one can observe that the sRGB values contain B=0.
          This indicates, that the Lab values cannot be converted to sRGB
          without clipping.
          Best regards --Gernot Hoffmann
          Message was edited by: Gernot Hoffmann
