3 Replies Latest reply on Jun 25, 2012 11:24 PM by prodic
    Succesful commands for Provisioning Tool(CS6/PC)
    prodic Level 3
      Have any of you guys had any luck using the Provisioning Tool to unserialize a CS6-installation?
      If so - what was the command line you used?
      We've tested various commands but none of them have been succesful.
      Some gives the return code 1 and a single one gives the return code 0.
      The one giving the return code 0 should work, but sadly it doesn't actually unserialize.
      Our CS6-package is made using AAMEE and packed as a serialized install.
      After the install we plan on unserializing the install, but have no luck doing so.
      The reason for this procedure is bad experiences trying to serialize a trial install of CS5.5.
      Kenneth
