First off, a big thank you to ja3754 for the great help with a previous question. : )
Now back to the challenge at hand...
I have an image of the Vitruvian Man.
I am trying to have a situation where I keep the line work of the drawing but get rid of the parchment or gold-ish background, in effect making a transparent image.
I think it might have something to do with using either the magic wand tool in Photoshop or the Live Trace feature in Illustrator or maybe both. However, after much looking around and viewing of videos, I still can't piece together a solution on how to do it.
I am also trying to simplify the line work of the drawing so it looks a little more "graphic" or logo-like.
This kind of simplification, in this case, involves mainly two things:
So, this is what I have to start with:
And I am trying to achieve something like the following:
or something like this:
Thanks for your help and advice!
If you are good in Illustrator you could probably trace the parts you want and set your weights, giving yo avector logo whoudh owuld be ideal, but a fair amount of work. The other option I would try myself wold be to use Select > Color Range in Photoshop to remove the bulk of the background (the trick is going to be setting the tolerance so you don't pull the lines, too), then clean up with eraser and brush tools. Also a lot of work.
Peter Spier wrote:
.. use Select > Color Range in Photoshop to remove the bulk of the background (the trick is going to be setting the tolerance so you don't pull the lines, too), then clean up with eraser and brush tools. Also a lot of work.
Adjust Brightness and Contrast before you do that, it might get you at least halfway. Then manually clean up with the eraser.
