4 Replies Latest reply on Jun 18, 2012 7:54 AM by [Jongware]
    assigning shortcuts for alignment of objects?
    arjun2 Level 1
      how can i assign following shortcuts to the reqd. commands? i couldn't find them in shortcuts preferences.
      e- align centres horizontally
      c - align centres of objects vertically
      b - align bottom of objects
        • 1. Re: assigning shortcuts for alignment of objects?
          Alec Molloy Employee Moderator
          Are you running OSX?
          • 2. Re: assigning shortcuts for alignment of objects?
            How did you look for them? Searching for 'align' gives me this list -- the actual terminology is slightly different than yours, but I think it includes the commands you are looking for.
            Product area : Object Editing
            Horizontal Align Centre --- [none defined]
            Horizontal Align Left --- [none defined]
            Horizontal Align Right --- [none defined]
            Horizontal Distribute Centre --- [none defined]
            Horizontal Distribute Left --- [none defined]
            Horizontal Distribute Right --- [none defined]
            Horizontal Distribute Space --- [none defined]
            Horizontal Margin Align Centre --- [none defined]
            Horizontal Margin Align Left --- [none defined]
            Horizontal Margin Align Right --- [none defined]
            Horizontal Page Align Centre --- [none defined]
            Horizontal Page Align Left --- [none defined]
            Horizontal Page Align Right --- [none defined]
            Horizontal Spread Align Centre --- [none defined]
            Horizontal Spread Align Left --- [none defined]
            Horizontal Spread Align Right --- [none defined]
            Vertical Align Bottom --- [none defined]
            Vertical Align Centre --- [none defined]
            Vertical Align Top --- [none defined]
            Vertical Distribute Bottom --- [none defined]
            Vertical Distribute Centre --- [none defined]
            Vertical Distribute Space --- [none defined]
            Vertical Distribute Top --- [none defined]
            Vertical Margin Align Bottom --- [none defined]
            Vertical Margin Align Centre --- [none defined]
            Vertical Margin Align Top --- [none defined]
            Vertical Page Align Bottom --- [none defined]
            Vertical Page Align Centre --- [none defined]
            Vertical Page Align Top --- [none defined]
            Vertical Spread Align Bottom --- [none defined]
            Vertical Spread Align Centre --- [none defined]
            Vertical Spread Align Top --- [none defined]
            • 3. Re: assigning shortcuts for alignment of objects?
              arjun2 Level 1
              thanks a lot ...i didn't go to this subcategory
              • 4. Re: assigning shortcuts for alignment of objects?
                Choose "Show Set" and you get a document in which you can search ...
