2 Replies Latest reply on Jun 18, 2012 8:46 AM by richruiz
    Sharepoint getlistitem with query
    richruiz Level 1
      I have an Flashbuilder 4.6 application that connects to SharePoint 2010 via the list web service calling getlistitems. It works fine until I try to add a query parameter. Below is my webservice in the application that works returning all list items.
      <mx:WebService id="SPws" wsdl="{wsdurl}" endpointURI="http://rich-hp/_vti_bin/Lists.asmx" fault="wsdlFault(event)" load="SPws_loadHandler(event)" >
      <mx:operation name="GetListItems"   fault="GLIFault(event)"  result="GLIResult(event)"   >
         <mx:request   xmlns="http://schemas.microsoft.com/sharepoint/soap/"  >
           <listName>{listid}</listName>
           <rowLimit>1000</rowLimit>
         </mx:request>
        </mx:operation>
      </mx:WebService>
      The problem is when I add the CAML query in red below SP throws an exception.
      <mx:WebService id="SPws" wsdl="{wsdurl}" endpointURI="http://rich-hp/_vti_bin/Lists.asmx" fault="wsdlFault(event)"load="SPws_loadHandler(event)" >
        <soap:query xmlns="http://schemas.microsoft.com/sharepoint/soap/">
         <soap:Where >
          <soap:Eq >
           <soap:FieldRef Name="CaseNumber" />
           <soap:Value Type="Text">AAA=9000</soap:Value>
          </soap:Eq>
         </soap:Where>
        </soap:query>
      </mx:request>
      </mx:operation>
      </mx:WebService>
      The exact same call from SoupUI works.
      Using Charles, I traced the request and can see why the error is happening. Below is the request Flex is sending tho SP.
      <SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:s="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
        <SOAP-ENV:Body>
          <tns:GetListItems xmlns:tns="http://schemas.microsoft.com/sharepoint/soap/">
            <tns:listName>452DA74C-4F14-44A5-B614-C4C4CEDEB06A</tns:listName>
            <tns:query>
              <tns:Name>CaseNumber</tns:Name>
              <tns:Value>AAA=9000</tns:Value>
            </tns:query>
            <tns:rowLimit>1000</tns:rowLimit>
          </tns:GetListItems>
        </SOAP-ENV:Body>
      </SOAP-ENV:Envelope>
      Here's the request that works from SoapUI
      <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:soap="http://schemas.microsoft.com/sharepoint/soap/">
         <soapenv:Header/>
         <soapenv:Body>
            <soap:GetListItems>
               <soap:listName>452DA74C-4F14-44A5-B614-C4C4CEDEB06A</soap:listName>
               <soap:rowLimit>1000</soap:rowLimit>
                <soap:Query>
         <soap:Where>
          <soap:Eq>
          </soap:Eq>
         </soap:Where>
        </soap:Query>
            </soap:GetListItems>
         </soapenv:Body>
      </soapenv:Envelope>
      Notice how the query is being reformated and changed when sent from the application. My question is is this a bug or is there someway to force flex to send the query as it is written?
      The excwption thrown is -  Element <Query> of parameter query is missing or invalid.
      This makes sense since it is invalid
      Rich Ruiz
