1 Reply Latest reply on Jul 2, 2012 7:34 PM by Amy Blankenship
    Preventing FB from creating "shadow" Class files
    Amy Blankenship Level 4
      Hi, all;
      I have pointed Flash Builder at a Flash xfl file to create a Flash Pro Project.
      my workspace is at
      leda/SCG
      the xfl is at
      leda/SCG/VJTPlatform3/Core/PlatformTest/PlatformTest.xfl
      For some reason, Flash Builder has created a directory at leda/SCG/PlatformTest which it is calling bin-debug. That wouldn't be such an issue, but what is happening is that it is creating a copy there, so every error or warning has two copies.
      If I double-click an error, I may get a file I can edit (well, I can edit either, but only one of them will have an actual effect), or I may get the "shadow" version. In addition, when I am running the program in debug mode and want to stop and fix a problem I see, I can't just do it right from the file I am stepping through, since this is always the "shadow" version.
      I can fix this for a few minutes by going into the build path and setting the output folder to the same directory I am working in, but it always comes back when I am not looking. I don't understand why FB has to create these files. When I work on a Flex project, it does not dump the as files to the bin-debug directory. Is this happening because I am working on a Flash Pro project, or is there some other difference I am not seeing? More importantly, how do I fix it?
      Regards;
      Amy
