4 Replies Latest reply on Jun 17, 2012 5:32 AM by c.pfaffenbichler
    Every image is in a transform box
    Sweetphotos72
      I have CS5 and when I drag a photo into an existing page it is in a transform box. On CS4 when I did the same thing that only happended when I selected the image to resize. I like to move my items around and resize as I go.   Is there a way to do this in CS5?
        • 1. Re: Every image is in a transform box
          Level 7
          When you drag an image in, you're placing it as a smart object - so you have to commit the transform.
          Yes, there is a preference "Place or Drag images as Smart Objects".
          • 2. Re: Every image is in a transform box
            c.pfaffenbichler Level 9
            Like Mr.Cox pointed out: Photoshop > Preferences > General > Options > Place or Drag …
            • 3. Re: Every image is in a transform box
              Sweetphotos72 Level 1
              The problem I am having is that every single file I open looks like this.  Once I click transform (which I have to) the layer no longer allows me to click and edit the layer.  I like to re-size my images in relation to the multiple images I place on a document.  My previous version of photoshop did not create a transform box with each new file.  Does anyone know how can I adjust photoshop so that it doesn't do this. I am using CS5 on a PC.   photoshop transform issue.jpg
              • 4. Re: Every image is in a transform box
                If the controls still appear after you have unchecked the Preference could it be you have »Show Transform Controls« in the Options Bar for the Mobe Tool?
                Could you post a screenshot with the Layers Panel visible?
                If there is any chance of repeated transfromations then placing as Smart Objects may be a good idea for you after all.
                What do you mean by »edit« in this case?
