5 Replies Latest reply on Jun 17, 2012 8:57 AM by Gernot Hoffmann
    Is there a L*A*B to Pantone lookup table/technique
    MarieMeyer Level 1
      If I know a color's L*A*B values, is there a way I can easily located the nearest Pantone color?  I don't currently own any of the books but would buy one if there is one that provides this capability. Maybe it is just me, but I find their produce range bewildering.
        • 1. Re: Is there a L*A*B to Pantone lookup table/technique
          Gernot Hoffmann Level 3
          Marie,
          you can search by Photoshop.
          An example:
          Color Picker
          Type Lab 60/50/40
          Color Library
          Choose e.g. Pantone Solid Coated
          Find immediately 7416C
          Read Lab 61/49/36
          Or you can search here:
          http://www.fho-emden.de/~hoffmann/swatch16032005.pdf
          Best regards --Gernot Hoffmann
          3 people found this helpful
          • 2. Re: Is there a L*A*B to Pantone lookup table/technique
            MarieMeyer Level 1
            Thanks very much. Your document is very interesting. Are those the official Pantone LAB values, or did you measure them?  Also, I'm curious: you used D50 for the LAB values but D65 for the RGB values - why switch? I am never certain of which if these two I should use for a conversion.
            • 3. Re: Is there a L*A*B to Pantone lookup table/technique
              Marie,
              I don't even mention the name Pantone in my doc. With a little help
              from a friend I found a data base.
              Pantone changes the values occasionally a little. Especially there is
              some uncertainty about the CMYK represention (which is anyway
              only valid for a specific Pantoe process). In any case of doubt define
              your CMYK process in Photoshop's Color Settings, define the Spot
              color by Lab and read the equivalent CMYK values. Many Spot
              colors are out of gamut for sRGB or AdobeRGB (see my doc - if
              a number 0 or 255 for R,G,B appears, then the RGB values are
              clipped. As well, many Spots cannot be reproduced by any CMYK
              system.
              D50 is the observer illuminant and the reference for Lab for paper
              prints, a convention.
              D65 defines the reference white point for some RGB color spaces
              like sRGB and AdobeRGB, but not for all:
              http://www.fho-emden.de/~hoffmann/cielab03022003.pdf
              page 10
              D65 is mostly used as monitor white. Some people consider it
              as a contradiction: monitor D65 - print D50 .
              Practically it works - a matter of adaptation (one doesn't view
              the monitor and a print side by side).
              • 4. Re: Is there a L*A*B to Pantone lookup table/technique
                MarieMeyer Level 1
                Thanks very much.  I have some several chips from the "Munsell Book of Color" and I want to reproduce their colors in an InDesign document. Do you know the software program Babelcolor CT&A? It does color conversions from many spaces to many spaces. So I could use it convert the Munsell notations to LAB. But I have to choose D50 or D65. Which would you recommend?
                • 5. Re: Is there a L*A*B to Pantone lookup table/technique
                  Marie,
                  in this doc - my Digital Munsell -
                  http://www.fho-emden.de/~hoffmann/munsell15052009.pdf
                  you'll find Lab and sRGB values for Illuminant/Reference D50.
                  Originally, the Munsell chips were valid under Illuminant C, which is
                  normally not available, outside of color laboratories.
                  Please read the introduction - the helpful friend is mentioned as well.
                  For printig read the recommendation about the PostScript mode.
                  Printing by a non-PS printer is useless (prone to errors) - the relevant
                  data are internally defined in Lab.
                  Hope this helps, we may continue tomorrow.
