1 Reply Latest reply on Jun 17, 2012 6:28 AM by kglad
    Problem with Contact form:/
    DaronPL
      the contakt form is not working on my page:/ dont know what is wrong:/ My serv is 000webhost.com i use google app for domain mx...
      This is code from form config:
              Please read this information to learn how to set up the contact form integrated
              into the template.
              This readme file explains in details the meaning of the settings that can be
              done in the fcContactFormConfiguration.xml configuration file.
              It is recommended for you to use an XML editor to make changes to this file
               because it’s less possible to make an error in the markup which can cause to
              a not working contact form.
      <contactFormConfiguration>
                  An e-mail address which will be used to receive messages from your contact form.
                  You can specify several e-mail addresses separating them with a comma.
                  For example: first_email@domain.com, second_email@domain.com, third@domain.com
          <emailTo>mymail@mydomain.pl</emailTo>
                  A server script type which will process sending e-mails. It depends on your
                  hosting and in the current version of the contact form it is allowed to use
                  two types:  php (Apache, PHP Hosting); asp (IIS web server, ASP).
          <serverProcessorType>PHP</serverProcessorType>
                  A name of the script file which process sending e-mails on your server (without
                  extension). The name contact is used by default.
          <serverProcessorFileName>contact</serverProcessorFileName>
                  Set whether to validate only required fields (true/false).  The default value is
                  true which means the not required fields of your contact form will not be validated.
                  For example if the e-mail field of your form is set as not required (imagine it)
                  the form will be processed even if the user types in an incorrect e-mail address.
          <validateRequiredOnly>false</validateRequiredOnly>
                  Set whether to submit the form when the Enter key is pressed even if the focus is
                  not on the Submit button (true/false).
          <submitFormOnEnter>false</submitFormOnEnter>
                  Text showing to the user when the form is submitted without any errors.
          <messageSentText>DZIEKUJE ZA WYSLANIE WIADOMOSCI</messageSentText>
                  Text showing in case the form is not submitted because of a server error.
          <messageSentFailedText>BLAD SERWERA</messageSentFailedText>
                  Text your visitor will see while waiting till the processing is over.
          <formProcessingText>WYSYLANIE...</formProcessingText>
                  Your SMTP server (for ASP only).
          <smtpServer>localhost</smtpServer>
                  Your SMTP port (for ASP only).
          <smtpPort>25</smtpPort>
                  Set whether to send the message as a plain text (true) or as HTML (false).
          <plainText>false</plainText>
                  ID of the input field (in the structure XML file) to use for the “from: â€&#157;
                  or email to use instead (for example: mailfrom@domainname.com).
          <emailFromSource>mymail@mydomain.pl</emailFromSource>
                  Subject of the e-mails that will be sent through this contact form or ID of
                  the input field (in the structure XML file) to use for the “subject: â€&#157; label
                  in your e-mail client.
          <subjectSource>MAIL from my page</subjectSource>
                  Validation error messages that are showing to the user when the form fails to
                  validate. The form supports different types of validators. You can change the
                  text of the error messages the validators produce here.
                  You can use the {LABEL} keyword in these messages. It will replace it with the
                  label value of the field where an error occurs.
          <validationErrorMessages>
                      A required field is not filled in.
              <message type="fieldIsRequired">{LABEL} WYMAGANE.</message>
                      The specified e-mail address is incorrect.
              <message type="emailNotValid">{LABEL} - NIEPOPRAWNY MAIL.</message>
                      The specified number of characters in a field is less than a required minimum.
              <message type="minCharsLimitError">{LABEL} - NIE OSIAGNIETO MINIMUM ZNAKOW.</message>
                      The specified string does not match with the regular expression.
              <message type="reqExpError">{LABEL} - The specified string does not match with the regular expression.</message>
                      The specified number is greater than an acceptable biggest number for this field.
              <message type="biggerThanMaxError">{LABEL} - The specified number is greater than an acceptable biggest number for this field.</message>
                      The specified number is lower than an acceptable lowest number for this field.
              <message type="lowerThanMinError">{LABEL} - The specified number is lower than an acceptable lowest number for this field.</message>
                      The data is not a number.
              <message type="notANumberError">{LABEL} - The data is not a number.</message>
                      The specified number must not be negative.
              <message type="negativeError">{LABEL} - The specified number must not be negative.</message>
                      The minimum number of variants is not selected
              <message type="minRequirementError">{LABEL} - The minimum number of variants is not selected</message>
                      The number of variants selected exceeds the maximum
              <message type="maxRequirementError">{LABEL} - The number of variants selected exceeds the maximum</message>
                      The fields that should be equal do not match
              <message type="shouldBeEqualError">{LABEL} - values do not match</message>
                       The date has wrong format.
              <message type="dateIsNotValidError">{LABEL} - date has wrong format</message>
          </validationErrorMessages>
      </contactFormConfiguration>
      And here is contakt.php ::
      <?php
      //-----------------Getting data sent by flash---------------------
      foreach ($_POST as $key => $value){
              if ($key != 'mail_to' && $key != 'smtp_server' && $key != 'smtp_port' && $key != 'mail_from' && $key != 'mail_subject' && $key != 'plain_text'){
                  $mail_body .= '<b>'.str_replace('_',' ',$key).'</b>:<br/>';
                  $mail_body .= ''.stripslashes($value).'<br/>';
      $message = '<html><body>'.$mail_body.'</body></html>'; //  mail body
      //------------if plain text is set to true removing html tags------
      if ($_POST['plain_text']=='true') {
          $message = str_replace('<br/>',"\r\n", $message);
          $message = strip_tags($message);
      } else {
      //----otherwise composing message headers---------------------------
          $headers  = 'MIME-Version: 1.0' . "\r\n";
          $headers .= 'Content-type: text/html; charset=iso-8859-1' . "\r\n";
      //------------setting conf data-------------------------------------
      $to = $_POST['mail_to'];
      $from = $_POST['mail_from'];
      $subject = $_POST['mail_subject'];
      $smtp_server = $_POST['smtp_server'];
      $smtp_port = $_POST['smtp_port'];
      //---------setting header info--------------------------------------
      $headers .= 'To: '.$to. "\r\n";
      $headers .= 'From: Site visitor ' .$from. "\r\n";
      if (mail($to, $subject, $message, $headers)){ // sending mail
          print('&mail=1');  //succes
      } else {
          print('&mail=0');//failure
      And structure my form :
      <contactFormStructure>
          <formItems>
              <item id="1" label="Name" required="true">
                  <textToShow>IMIE:</textToShow>
              </item>
              <item id="2" label="E-mail" required="true">
                  <textToShow>E-MAIL:</textToShow>
                  <validator>EmailValidator</validator>
              </item>
              <item id="3" label="Address">
                  <textToShow>ADRES:</textToShow>
              </item>
              <item id="4" label="Message" required="true">
                  <textToShow>WIADOMOSC:</textToShow>
              </item>
          </formItems>
      </contactFormStructure>
        • 1. Re: Problem with Contact form:/
          i'm not sure what you're doing with either of those xml files but it's probably easier to work backwards and use the trace function to see what you're sending to your php file.
          copy and paste the code that calls your php file and trace the variables you're sending.
