4 Replies Latest reply on Jun 18, 2012 6:07 AM by adninjastrator
    soundcloud widget !!!
    olcayd
      I have buid a full flash web page and I want to embed soundcloud widget in it, is this possible ? How can I manage it ?
        • 1. Re: soundcloud widget !!!
          adninjastrator Level 4
          One option on embedding HTML widgets into Flash is suggested in my last reply in this post:
          http://forums.adobe.com/message/4494968#4494968
          Best wishes,
          Adninjastrator
          • 2. Re: soundcloud widget !!!
            olcayd Level 1
            Thanks a lot this is amazing IF YOU HAVE ONLY ONE PAGE will it work in this scenario
            Lets go step by step, (I want to be sure if I understood right since Im a new user)
            1. I publish my flash site and open it in dreamweaver and enter the z-index codes in dreamweaver...
            2. publish my html vers... and upload to server....
            In this way I will have a problem I guess because . when my site opened it starts with the homepage and there shouldn't be a soundcloud widget which is visible... and also I have different playlists in soundcloud and i want to separate each of them in a different page in my flash...
            ex: (the site is not in english)
            i want a soundcloud playlist in "aranjeler" tab and one another in "besteler" and one another in "mix" tab etc... :S
            here is the site (as a draft) :  www.olcaydemirci.com
            By the way thanks a lot for the reply. I hope you have one more solution
            • 3. Re: soundcloud widget !!!
              olcayd Level 1
              I did what you told me, and also decided not to use more pages, I mean this solution ok for me BUT I cant fix my player in the browser : it stands in different places in IE and chrome and other browsers, moreover safari even doesn't display it....
              here is my html code that i use in dreamweaver:
              <head>
              <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
              <title>olcay demirci - aranje,mix,mastering</title>
              </head>
              <body bgcolor="#000000">
              <!--url's used in the movie-->
              <!--text used in the movie-->
              <p align="left"><font face="Shonar Bangla" size="26" color="#990072" letterSpacing="0.000000" kerning="0"><b>aranjör-besteci-ses mühendisi-müzisyen</b></font></p>
              <!-- saved from url=(0013)about:internet -->
              <object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" codebase="http://fpdownload.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=8,0,0,0" width="100%" height="100%" id="index" align="middle">
              <param name="allowScriptAccess" value="sameDomain" />
              <param name="movie" value="index.swf" /><param name="quality" value="best" /><param name="scale" value="noscale" /><param name="bgcolor" value="#000000" /><embed src="index.swf" quality="best" scale="noscale" bgcolor="#000000" width="100%" height="100%" name="index" align="middle" allowScriptAccess="sameDomain" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer" />
              </object>
              </body>
              </html>
              <!player>
              <div style="position:relative; top:-265; left:827; z-index:2">
              <iframe width="33%" height="166" scrolling="yes" frameborder="no"
              src="http://w.soundcloud.com/player/?url=http%3A%2F%2Fapi.soundcloud.com%2Ftracks%2F49743966&am p;auto_play=true&amp;
              show_artwork=false&amp;color=ec0aea"></iframe>
              • 4. Re: soundcloud widget !!!
                The HTML needs a little work...
                To start with you need a DOCTYPE declaration as the first line of the code.... VERY IMPORTANT!!
                http://www.w3schools.com/tags/tag_doctype.asp
                Don't know what this is or why you are using it
                <!player>
                remove if you don't need it... were you meaning that as a comment? if so
                <!--  player -->
                would be the correct syntax
                Next, all this content is outside the <body> and even the <html>
                <iframe width="33%" height="166" scrolling="no" frameborder="no"
                all content must be inside the <body>.
                Then notice that you have an opening <div tag ... then an <iframe>, but no closing </div> tag.
                Easy to check coding errors yourself by validating the code here:
                http://validator.w3.org/
                Until the code validates, your not going to get consistent results across various browsers.
                Best wishes,
                Adninjastrator
