6 Replies Latest reply on Jun 18, 2012 1:46 AM by adama543
    ae cs6 expression
    adama543
      hello
      im running cs6 and i have a simple if else expression on the opacity
      and its linked to a checkbox (expression control) on acomp above
      the expression works up until i animate the checkbox
      i used the slider control just to see
      the result was the same  i used this expression in cs5 all the time
      and this project depends on it
      PLEASE HELP
        • 1. Re: ae cs6 expression
          Probably yet another ridiculous bug in the crappy new cacheing system. Turn off the disk cache in the prefs. Also consider baking the expressions to keyframes. No matter what, it will probably render correctly either way, it's just not behaving correctly for previews.
          Mylenium
          • 2. Re: ae cs6 expression
            adama543 Level 1
            thanks for the reply mylenium
            turned it off still doesnt work
            already checked render and the render looks like  the preview
            i never baked expression do you mind telling me how i can accomplish that ?
            do i need a plugin ?
            adam
            • 3. Re: ae cs6 expression
              Animation --> Keyframe Assistants --> Convert Expression to Keyframes
              Mylenium
              • 4. Re: ae cs6 expression
                adama543 Level 1
                well after checking it out
                i must say i dont really know what the cause of this weird behavior
                it sometimes work and most of the time doesn't and not the caching\uncaching it or baking it soulvs it completly
                but checking the caching off has an affect on it  and thats not afix not at all
                i would say the  most unreliable cs version  yet  im saying it after encountering loads of bugs not only that one (viewport glitches and what have you )
                and being an after effects user/enthusiast for along time
                say mylenium
                when do you think the next update will arrive (im using 11.0.1.12)?
                • 5. Re: ae cs6 expression
                  I have no idea, but I wouldn't keep my hopes up. AE has never received any meaningful patch releases beyond updating stuff like RED importers or similar for which I couldn't care less, so the next fix will be the next paid upgrade most likely, whether that's CS6.5 or CS7 remains to be seen...
                  Mylenium
                  • 6. Re: ae cs6 expression
                    adama543 Level 1
                    i had time to check it again.
                    i restarted my pc out of superstitious reasons and started anew project with
                    caching turned off this time my expression worked
                    so yea..... all that money for an ssd
                    the latest update had something to do with expression
                    i hope next time they tackle the caching system
                    for   the human race
                    adam
