4 Replies Latest reply on Jun 17, 2012 4:47 PM by romeup17649921
    Indesign CS6 trial version installation failling
    romeup17649921 Level 1
      I'm trying to install a trial version of Adobe Indesign CS6 on a (2009) Mac mini 2.26 Ghz Core 2 Duo with 4Gb Ram. The internal hard drive still has 18Gb free space that should be enough to install just indesign. I tried several times (after reboot, rebuild permissions, etc.), even in a new (admin) user that I created just to try the indesign installation, same error. Bellow I include the error summary log that the installer supplies after aborting the installation:
      Exit Code: 7
      Please see specific errors and warnings below for troubleshooting. For example,  ERROR: DW050 ...
      -------------------------------------- Summary --------------------------------------
      - 0 fatal error(s), 41 error(s), 0 warning(s)
      ERROR: Updating driver data failed. Driver entry was notadded. ARP estimated size 3726KB
      ERROR: DW050: The following payload errors were found during install:
      ERROR: DW050:  - Suite Shared Configuration CS6: Install failed
      ERROR: DW050:  - Adobe Linguistics CS6: Install failed
      ERROR: DW050:  - AdobeColorCommonSetCMYK CS6: Install failed
      ERROR: DW050:  - Adobe InDesign CS6 Common Base Files: Install failed
      ERROR: DW050:  - DPS Desktop Tools CS6: Install failed
      ERROR: DW050:  - Adobe XMP Panels: Install failed
      ERROR: DW050:  - Adobe Player for Embedding 3.3: Install failed
      ERROR: DW050:  - AdobeColorJA CS6: Install failed
      ERROR: DW050:  - Required Common Fonts Installation: Install failed
      ERROR: DW050:  - Adobe InDesign CS6 Application Base Files: Failed due to Language Pack installation failure
      ERROR: DW050:  - Adobe CSXS Infrastructure CS6: Install failed
      ERROR: DW050:  - Adobe InDesign CS6 Common Language Files_AdobeInDesign8CommonLang-en_US: Install failed
      ERROR: DW050:  - PDF Settings CS6: Install failed
      ERROR: DW050:  - Adobe Utilities CS6: Install failed
      ERROR: DW050:  - Adobe SwitchBoard 2.0: Install failed
      ERROR: DW050:  - Adobe ExtendScript Toolkit CS6: Install failed
      ERROR: DW050:  - AdobeColorEU CS6: Install failed
      ERROR: DW050:  - Camera Profiles Installer: Install failed
      ERROR: DW050:  - AdobePDFL CS6: Install failed
      ERROR: DW050:  - Adobe InDesign CS6 Application Feature Set Files: Install failed
      ERROR: DW050:  - Adobe InDesign CS6 Application Base Files2: Install failed
      ERROR: DW050:  - Adobe Extension Manager CS6: Install failed
      ERROR: DW050:  - Adobe NPS Panel: Install failed
      ERROR: DW050:  - PDF Settings CS5: Install failed
      ERROR: DW050:  - Adobe Bridge CS6: Install failed
      ERROR: DW050:  - AdobeTypeSupport CS6: Install failed
      ERROR: DW050:  - Adobe WinSoft Linguistics Plugin CS6: Install failed
      ERROR: DW050:  - AdobeHelp: Install failed
      ERROR: DW050:  - Adobe Hunspell Linguistics Plugin CS6: Install failed
      ERROR: DW050:  - Adobe Mini Bridge CS6: Install failed
      ERROR: DW050:  - Adobe Toolhints CS6: Install failed
      ERROR: DW050:  - AdobeColorNA CS6: Install failed
      ERROR: DW050:  - AdobeColorCommonSetRGB CS6: Install failed
      ERROR: DW050:  - Adobe Media Encoder CS6: Install failed
      ERROR: DW050:  - Photoshop Camera Raw 7: Install failed
      ERROR: DW050:  - Recommended Common Fonts Installation: Install failed
      ERROR: DW050:  - DynamiclinkSupport: Install failed
      ERROR: DW050:  - Adobe InDesign CS6 Application Language Files_AdobeInDesign8AppLang-en_US: Install failed
      ERROR: DW050:  - AdobeCMaps CS6: Install failed
      ERROR: DW050:  - Adobe CSXS Extensions CS6: Install failed
      Anyone else with the same problem? How can I fix this?
      Thanks for any help.
