0 Replies Latest reply on Jun 17, 2012 9:44 PM by vincent.racaza
    Converting Mx Datagrid to Spark Datagrid
    vincent.racaza
      Do you know how to convert this one into spark datagrid?
      package
      import flash.display.Sprite;
      import flash.events.KeyboardEvent;
      import mx.controls.CheckBox;
      import mx.controls.DataGrid;
      import mx.controls.listClasses.IListItemRenderer;
      *  DataGrid that uses checkboxes for multiple selection
      public class CheckBoxDataGrid extends DataGrid
      //what is the equivalent method of Spark datagrid??
                override protected function selectItem(item:IListItemRenderer,
                                        shiftKey:Boolean, ctrlKey:Boolean,
                                        transition:Boolean = true):Boolean
                          // only run selection code if a checkbox was hit and always
                          // pretend we're using ctrl selection
                          if (item is CheckBox)
                                    return super.selectItem(item, false, true, transition);
                          return false;
                // turn off selection indicator
          override protected function drawSelectionIndicator(
                                      indicator:Sprite, x:Number, y:Number,
                                      width:Number, height:Number, color:uint,
                                      itemRenderer:IListItemRenderer):void
                // whenever we draw the renderer, make sure we re-eval the checked state
          override protected function drawItem(item:IListItemRenderer,
                                      selected:Boolean = false,
                                      highlighted:Boolean = false,
                                      caret:Boolean = false,
                                      transition:Boolean = false):void
                  CheckBox(item).invalidateProperties();
                          super.drawItem(item, selected, highlighted, caret, transition);
                // fake all keyboard interaction as if it had the ctrl key down
                override protected function keyDownHandler(event:KeyboardEvent):void
                          // this is technically illegal, but works
                          event.ctrlKey = true;
                          event.shiftKey = false;
                          super.keyDownHandler(event);
      Please! I need your help! Thanks!
