1 Reply Latest reply on Jun 18, 2012 8:04 AM by Frustrated in AZ
    EBooks not showing up in Library
    mackaicarlos
      I am downloading Ebooks into ADE and although they are showing up in the 'Reader View', when I click on 'Library' the book is not there and I can't get back to the 'Reader View'
      Any ideas??
        • 1. Re: EBooks not showing up in Library
          Level 4
          Yes.  The ebooks are there, but when you downloaded them, you had a choice
          whether to OPEN or SAVE them.  If you OPEN an ebook, ADE will download them
          and bring it up in Reading view.  If you SAVE them, ADE will put them in
          the library, and you'll see them in Library view.
          You can 'fix' this.  ADE uses an area on your hard disk called My Digital
          Editions to store the ebooks.  You can open ADE in Library view, then put
          your cursor on the small arrow next to the word 'Library'.  A drop-down
          menu will show up.  Click on 'Add Item to Library', and another window will
          open up, permitting you to specify where the ebook is and its name.  You
          can double-click on the ebook name, and then click on OK.  The ebook will
          be added to the Library.  You can't do multiples - only one at a time, so I
          hope you didn't download a bunch....  Also, ebooks that show up in Reading
          view will still show up there, so you can finish reading them.
          If you need more help, just read the ADE HELP section (the F1 key from
          either Reading or Library view).  There's lots of information about how ADE
          works, and what you can do with it.
