15 Replies Latest reply on Feb 28, 2013 9:12 PM by tobby7332002
    Photoshop CS6 3D menu grey out
    tobby7332002
      Hi everyone. I am now trying to use photoshop CS6 3D features. And I found out that no matter what I select, the 3D menu is still grey out.
      What should I do to solve this?
      I see some of you said that your 3D menu is missing because of the graphic card issue.  For my case, what should I do? Thank you
        • 1. Re: Photoshop CS6 3D menu grey out
          Curt Y Level 7
          In CS6 if you have XP OS it will not work.  Need Win 7.
          • 2. Re: Photoshop CS6 3D menu grey out
            Noel Carboni Level 8
            It might be helpful if you'd go to your Help - System Info... menu, Copy, then paste the info here.
            -Noel
            • 3. Re: Photoshop CS6 3D menu grey out
              SG... Adobe Employee
              Most likely you're running into problems associated with the graphics card or driver. As Noel mentions, providing the system info will help us to determine further steps.
              Curt, on XP systems the 3D menu is not present even when Ps Extended is activated.
              regards,
              steve
              • 4. Re: Photoshop CS6 3D menu grey out
                tobby7332002 Level 1
                Thanks for all your help. This is my system info.
                Adobe Photoshop Version: 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) x64
                Operating System: Windows 7 64-bit
                Version: 6.1 Service Pack 1
                System architecture: AMD CPU Family:15, Model:4, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3
                Physical processor count: 4
                Processor speed: 3199 MHz
                Built-in memory: 8191 MB
                Free memory: 4730 MB
                Memory available to Photoshop: 7242 MB
                Memory used by Photoshop: 60 %
                Image tile size: 132K
                Image cache levels: 4
                OpenGL Drawing: Enabled.
                OpenGL Drawing Mode: Advanced
                OpenGL Allow Normal Mode: True.
                OpenGL Allow Advanced Mode: True.
                OpenGL Allow Old GPUs: Not Detected.
                Video Card Vendor: ATI Technologies Inc.
                Video Card Renderer: AMD Radeon HD 6600 Series
                Display: 2
                Display Bounds:=  top: 0, left: 1920, bottom: 768, right: 2944
                Display: 1
                Display Bounds:=  top: 0, left: 0, bottom: 1080, right: 1920
                Video Card Number: 1
                Video Card: AMD Radeon HD 6600 Series
                OpenCL Unavailable
                Driver Version: 8.840.0.0
                Driver Date: 20110309000000.000000-000
                Video Card Driver: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.d ll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
                Video Mode: 1920 x 1080 x 4294967296 colors
                Video Card Caption: AMD Radeon HD 6600 Series
                Video Card Memory: 1024 MB
                Video Rect Texture Size: 16384
                Serial number: 92298873351362507577
                Application folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\
                Temporary file path: C:\Users\Tobby\AppData\Local\Temp\
                Photoshop scratch has async I/O enabled
                Scratch volume(s):
                  C:\, 638.5G, 245.2G free
                Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Required\
                Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\
                Additional Plug-ins folder: not set
                Installed components:
                   A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                   ACE.dll   ACE 2012/01/18-15:07:40   66.492997   66.492997
                   adbeape.dll   Adobe APE 2012/01/25-10:04:55   66.1025012   66.1025012
                   AdobeLinguistic.dll   Adobe Linguisitc Library   6.0.0
                   AdobeOwl.dll   Adobe Owl 2012/02/09-16:00:02   4.0.93   66.496052
                   AdobePDFL.dll   PDFL 2011/12/12-16:12:37   66.419471   66.419471
                   AdobePIP.dll   Adobe Product Improvement Program   6.0.0.1654
                   AdobeXMP.dll   Adobe XMP Core 2012/02/06-14:56:27   66.145661   66.145661
                   AdobeXMPFiles.dll   Adobe XMP Files 2012/02/06-14:56:27   66.145661   66.145661
                   AdobeXMPScript.dll   Adobe XMP Script 2012/02/06-14:56:27   66.145661   66.145661
                   adobe_caps.dll   Adobe CAPS   6,0,29,0
                   AGM.dll   AGM 2012/01/18-15:07:40   66.492997   66.492997
                   ahclient.dll    AdobeHelp Dynamic Link Library   1,7,0,56
                   aif_core.dll   AIF   3.0   62.490293
                   aif_ocl.dll   AIF   3.0   62.490293
                   aif_ogl.dll   AIF   3.0   62.490293
                   amtlib.dll   AMTLib (64 Bit)   6.0.0.75 (BuildVersion: 6.0; BuildDate: Mon Jan 16 2012 18:00:00)   1.000000
                   ARE.dll   ARE 2012/01/18-15:07:40   66.492997   66.492997
                   AXE8SharedExpat.dll   AXE8SharedExpat 2011/12/16-15:10:49   66.26830   66.26830
                   AXEDOMCore.dll   AXEDOMCore 2011/12/16-15:10:49   66.26830   66.26830
                   Bib.dll   BIB 2012/01/18-15:07:40   66.492997   66.492997
                   BIBUtils.dll   BIBUtils 2012/01/18-15:07:40   66.492997   66.492997
                   boost_date_time.dll   DVA Product   6.0.0
                   boost_signals.dll   DVA Product   6.0.0
                   boost_system.dll   DVA Product   6.0.0
                   boost_threads.dll   DVA Product   6.0.0
                   cg.dll   NVIDIA Cg Runtime   3.0.00007
                   cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                   CIT.dll   Adobe CIT   2.0.5.19287   2.0.5.19287
                   CoolType.dll   CoolType 2012/01/18-15:07:40   66.492997   66.492997
                   data_flow.dll   AIF   3.0   62.490293
                   dvaaudiodevice.dll   DVA Product   6.0.0
                   dvacore.dll   DVA Product   6.0.0
                   dvamarshal.dll   DVA Product   6.0.0
                   dvamediatypes.dll   DVA Product   6.0.0
                   dvaplayer.dll   DVA Product   6.0.0
                   dvatransport.dll   DVA Product   6.0.0
                   dvaunittesting.dll   DVA Product   6.0.0
                   dynamiclink.dll   DVA Product   6.0.0
                   ExtendScript.dll   ExtendScript 2011/12/14-15:08:46   66.490082   66.490082
                   FileInfo.dll   Adobe XMP FileInfo 2012/01/17-15:11:19   66.145433   66.145433
                   filter_graph.dll   AIF   3.0   62.490293
                   hydra_filters.dll   AIF   3.0   62.490293
                   icucnv40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
                   icudt40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
                   image_compiler.dll   AIF   3.0   62.490293
                   image_flow.dll   AIF   3.0   62.490293
                   image_runtime.dll   AIF   3.0   62.490293
                   JP2KLib.dll   JP2KLib 2011/12/12-16:12:37   66.236923   66.236923
                   libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                   libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   10.0
                   LogSession.dll   LogSession   2.1.2.1640
                   mediacoreif.dll   DVA Product   6.0.0
                   MPS.dll   MPS 2012/02/03-10:33:13   66.495174   66.495174
                   msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                   msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                   msvcp100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
                   msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                   msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                   msvcr100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
                   msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                   msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                   pdfsettings.dll   Adobe PDFSettings   1.04
                   Photoshop.dll   Adobe Photoshop CS6   CS6
                   Plugin.dll   Adobe Photoshop CS6   CS6
                   PlugPlug.dll   Adobe(R) CSXS PlugPlug Standard Dll (64 bit)   3.0.0.383
                   PSArt.dll   Adobe Photoshop CS6   CS6
                   PSViews.dll   Adobe Photoshop CS6   CS6
                   SCCore.dll   ScCore 2011/12/14-15:08:46   66.490082   66.490082
                   ScriptUIFlex.dll   ScriptUIFlex 2011/12/14-15:08:46   66.490082   66.490082
                   tbb.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
                   tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
                   TfFontMgr.dll   FontMgr   9.3.0.113
                   TfKernel.dll   Kernel   9.3.0.113
                   TFKGEOM.dll   Kernel Geom   9.3.0.113
                   TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                   updaternotifications.dll   Adobe Updater Notifications Library   6.0.0.24 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   6.0.0.24
                   WRServices.dll   WRServices Friday January 27 2012 13:22:12   Build 0.17112   0.17112
                   wu3d.dll   U3D Writer   9.3.0.113
                Required plug-ins:
                   3D Studio 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Accented Edges 13.0
                   Adaptive Wide Angle 13.0
                   ADM 3.11x01
                   Angled Strokes 13.0
                   Average 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Bas Relief 13.0
                   BMP 13.0
                   Camera Raw 7.0
                   Chalk & Charcoal 13.0
                   Charcoal 13.0
                   Chrome 13.0
                   Cineon 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Clouds 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Collada 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Color Halftone 13.0
                   Colored Pencil 13.0
                   CompuServe GIF 13.0
                   Conté Crayon 13.0
                   Craquelure 13.0
                   Crop and Straighten Photos 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Crop and Straighten Photos Filter 13.0
                   Crosshatch 13.0
                   Crystallize 13.0
                   Cutout 13.0
                   Dark Strokes 13.0
                   De-Interlace 13.0
                   Dicom 13.0
                   Difference Clouds 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Diffuse Glow 13.0
                   Displace 13.0
                   Dry Brush 13.0
                   Eazel Acquire 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Embed Watermark 4.0
                   Entropy 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Extrude 13.0
                   FastCore Routines 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Fibers 13.0
                   Film Grain 13.0
                   Filter Gallery 13.0
                   Flash 3D 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Fresco 13.0
                   Glass 13.0
                   Glowing Edges 13.0
                   Google Earth 4 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Grain 13.0
                   Graphic Pen 13.0
                   Halftone Pattern 13.0
                   HDRMergeUI 13.0
                   IFF Format 13.0
                   Ink Outlines 13.0
                   JPEG 2000 13.0
                   Kurtosis 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Lens Blur 13.0
                   Lens Correction 13.0
                   Lens Flare 13.0
                   Liquify 13.0
                   Matlab Operation 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Maximum 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Mean 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Measurement Core 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Median 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Mezzotint 13.0
                   Minimum 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   MMXCore Routines 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Mosaic Tiles 13.0
                   Multiprocessor Support 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Neon Glow 13.0
                   Note Paper 13.0
                   NTSC Colors 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Ocean Ripple 13.0
                   Oil Paint 13.0
                   OpenEXR 13.0
                   Paint Daubs 13.0
                   Palette Knife 13.0
                   Patchwork 13.0
                   Paths to Illustrator 13.0
                   PCX 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Photocopy 13.0
                   Photoshop 3D Engine 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Picture Package Filter 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Pinch 13.0
                   Pixar 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Plaster 13.0
                   Plastic Wrap 13.0
                   PNG 13.0
                   Pointillize 13.0
                   Polar Coordinates 13.0
                   Portable Bit Map 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Poster Edges 13.0
                   Radial Blur 13.0
                   Radiance 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Range 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Read Watermark 4.0
                   Reticulation 13.0
                   Ripple 13.0
                   Rough Pastels 13.0
                   Save for Web 13.0
                   ScriptingSupport 13.0
                   Shear 13.0
                   Skewness 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Smart Blur 13.0
                   Smudge Stick 13.0
                   Solarize 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Spatter 13.0
                   Spherize 13.0
                   Sponge 13.0
                   Sprayed Strokes 13.0
                   Stained Glass 13.0
                   Stamp 13.0
                   Standard Deviation 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Sumi-e 13.0
                   Summation 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Targa 13.0
                   Texturizer 13.0
                   Tiles 13.0
                   Torn Edges 13.0
                   Twirl 13.0
                   U3D 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Underpainting 13.0
                   Vanishing Point 13.0
                   Variance 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Variations 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Water Paper 13.0
                   Watercolor 13.0
                   Wave 13.0
                   Wavefront|OBJ 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   WIA Support 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   Wind 13.0
                   Wireless Bitmap 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
                   ZigZag 13.0
                Optional and third party plug-ins: NONE
                Plug-ins that failed to load: NONE
                Flash: NONE
                Installed TWAIN devices: NONE
                • 5. Re: Photoshop CS6 3D menu grey out
                  Thanks for the additional info.  I see that your display driver is out of date.  But you don't want the very latest one (Catalyst 12.4 is known to have problems).
                  What you should do is go to this page, and download and install the Catalyst Software Suite version 12.2, which is known to work well with Photoshop:
                  http://support.amd.com/us/gpudownload/windows/previous/12/Pages/radeon.aspx?os=Windows%20V ista%20-%2064-Bit%20Edition&rev=12.2
                  -Noel
                  • 6. Re: Photoshop CS6 3D menu grey out
                    Cool. My problem is fixed now. Thank you so much !!! This really help!
                    • 7. Re: Photoshop CS6 3D menu grey out
                      You're welcome!  Glad to hear you've got things working now.
                      -Noel
                      • 8. Re: Photoshop CS6 3D menu grey out
                        MattLeger
                        ...on XP systems the 3D menu is not present even when Ps Extended is activated.<<
                        Does this apply to Windows Vista computers as well? I have a six-year-old 32-bit Sony VAIO running Vista with the latest service packs and have the same problem with the 3D menu in PSCS6. Is Adobe now getting so hard-assed about hardware requirements that I will have to shell out several hundred $$$ I don't have to upgrade my laptop just to get full functionality out of the latest Creative Suite?
                        • 9. Re: Photoshop CS6 3D menu grey out
                          Level 7
                          Vista isn't a supported OS version for Photoshop CS6.
                          Photoshop just requires hardware and drivers that work correctly.
                          • 10. Re: Photoshop CS6 3D menu grey out
                            ShawnMay
                            Hi Noel,  I just upgraded to creative cloud.  When I first launched PSCS6 this morning, 3D was working perfectly. This afternoon, I performed the full battery of updates, after which, the items in the 3D menu now show up as grey.
                            PSCS5.1 3D space is still working find though.  If you have any ideas...
                            Adobe Photoshop Version: 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00) x64
                            System architecture: Intel CPU Family:6, Model:7, Stepping:10 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1
                            Physical processor count: 2
                            Processor speed: 2660 MHz
                            Built-in memory: 4084 MB
                            Free memory: 1353 MB
                            Memory available to Photoshop: 3455 MB
                            Image tile size: 128K
                            OpenGL Drawing Mode: Basic
                            OpenCL Unavailable
                            OpenGL Version: 3.0
                            Video Rect Texture Size: 8192
                            OpenGL Memory: 256 MB
                            Video Card Vendor: NVIDIA Corporation
                            Video Card Renderer: Quadro NVS 160M/PCI/SSE2
                            Display: 1
                            Display Bounds: top=0, left=0, bottom=1080, right=1920
                            Video Card: NVIDIA Quadro NVS 160M
                            Driver Version: 8.16.11.8992
                            Driver Date: 20100512000000.000000-000
                            Video Card Driver: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
                            Video Card Caption: NVIDIA Quadro NVS 160M
                            Video Card Memory: 256 MB
                            Serial number: 90970151512263312554
                            Temporary file path: C:\Users\Shawn\AppData\Local\Temp\
                            Scratch volume(s):
                              Startup, 222.6G, 6.04G free
                               ACE.dll   ACE 2012/06/05-15:16:32   66.507768   66.507768
                               AdobeOwl.dll   Adobe Owl 2012/09/10-12:31:21   5.0.4   79.517869
                               AdobePIP.dll   Adobe Product Improvement Program   7.0.0.1686
                               AGM.dll   AGM 2012/06/05-15:16:32   66.507768   66.507768
                               ARE.dll   ARE 2012/06/05-15:16:32   66.507768   66.507768
                               Bib.dll   BIB 2012/06/05-15:16:32   66.507768   66.507768
                               BIBUtils.dll   BIBUtils 2012/06/05-15:16:32   66.507768   66.507768
                               CIT.dll   Adobe CIT   2.1.0.20577   2.1.0.20577
                               CoolType.dll   CoolType 2012/06/05-15:16:32   66.507768   66.507768
                               libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                               LogSession.dll   LogSession   2.1.2.1681
                               svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                            Required plug-ins:
                               3D Studio 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Accented Edges 13.0
                               Angled Strokes 13.0
                               Average 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Bas Relief 13.0
                               BMP 13.0
                               Camera Raw 7.3
                               Charcoal 13.0
                               Chrome 13.0
                               Cineon 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Clouds 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Collada 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Color Halftone 13.0
                               Colored Pencil 13.0
                               CompuServe GIF 13.0
                               Conté Crayon 13.0
                               Craquelure 13.0
                               Crop and Straighten Photos 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Crosshatch 13.0
                               Crystallize 13.0
                               Cutout 13.0
                               Dark Strokes 13.0
                               De-Interlace 13.0
                               Dicom 13.0
                               Difference Clouds 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Diffuse Glow 13.0
                               Displace 13.0
                               Dry Brush 13.0
                               Eazel Acquire 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Embed Watermark 4.0
                               Entropy 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Extrude 13.0
                               FastCore Routines 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Fibers 13.0
                               Film Grain 13.0
                               Filter Gallery 13.0
                               Flash 3D 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Fresco 13.0
                               Glass 13.0
                               Glowing Edges 13.0
                               Google Earth 4 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Grain 13.0
                               Graphic Pen 13.0
                               HDRMergeUI 13.0
                               IFF Format 13.0
                               Ink Outlines 13.0
                               JPEG 2000 13.0
                               Kurtosis 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Lens Blur 13.0
                               Lens Flare 13.0
                               Liquify 13.0
                               Matlab Operation 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Maximum 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Mean 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Measurement Core 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Median 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Mezzotint 13.0
                               Minimum 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               MMXCore Routines 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Mosaic Tiles 13.0
                               Multiprocessor Support 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Neon Glow 13.0
                               Note Paper 13.0
                               NTSC Colors 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Ocean Ripple 13.0
                               Oil Paint 13.0
                               OpenEXR 13.0
                               Paint Daubs 13.0
                               Palette Knife 13.0
                               Patchwork 13.0
                               PCX 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Photocopy 13.0
                               Photoshop 3D Engine 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Picture Package Filter 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Pinch 13.0
                               Pixar 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Plaster 13.0
                               Plastic Wrap 13.0
                               PNG 13.0
                               Pointillize 13.0
                               Portable Bit Map 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Poster Edges 13.0
                               Radial Blur 13.0
                               Radiance 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Range 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Read Watermark 4.0
                               Reticulation 13.0
                               Ripple 13.0
                               Rough Pastels 13.0
                               Save for Web 13.0
                               ScriptingSupport 13.1.2
                               Shear 13.0
                               Skewness 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Smart Blur 13.0
                               Smudge Stick 13.0
                               Solarize 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Spatter 13.0
                               Spherize 13.0
                               Sponge 13.0
                               Stained Glass 13.0
                               Stamp 13.0
                               Standard Deviation 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               STL 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Sumi-e 13.0
                               Summation 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Targa 13.0
                               Texturizer 13.0
                               Tiles 13.0
                               Torn Edges 13.0
                               Twirl 13.0
                               Underpainting 13.0
                               Variance 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Variations 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Water Paper 13.0
                               Watercolor 13.0
                               Wave 13.0
                               Wavefront|OBJ 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               WIA Support 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               Wind 13.0
                               Wireless Bitmap 13.1.2 (13.1.2 20130105.r.224 2013/01/05:23:00:00)
                               ZigZag 13.0
                            Flash: NONE
                            • 11. Re: Photoshop CS6 3D menu grey out
                              I do know why you can't get to 3D functions, I believe, though you're likely not going to like hearing it.
                              Adobe, with their recent updates, have made some advancements in the 3D area, and as such have tightened up the requirements that have always been published about Photoshop CS6 needing 512MB of VRAM.
                              You don't have 512MB, from what you showed of your System Information.
                              I don't know what kind of computer you have, but I see your video "card" is a Quadro NVS 160M (M implying "mobile").  If you can't upgrade the display interface in the system (e.g., by buying a new card), you may be faced with uninstalling Photoshop and reinstalling the 13.0.0 version, then avoiding updates if you want the 3D functionality.
                              -Noel
                              • 12. Re: Photoshop CS6 3D menu grey out
                                Hi Shawn,
                                It appears that your video card is under the minimum requirements for the latest 13.1 update.
                                Are you not seeing the dialog about 3D feature requirements?
                                http://blogs.adobe.com/crawlspace/2012/10/heads-up-photoshop-system-requirement-changes.ht ml
                                We didn't disable the 3D menu items with 13.0, even though the system requirements were still 512 MB VRAM. We changed it because there were too many problem reports coming from systems with VRAM below the 512 MB requirement.
                                regards,
                                steve
                                • 13. Re: Photoshop CS6 3D menu grey out
                                  gewoonchill
                                  Hi Noel,
                                  i've the the same problem, the 3d menu is grey out. I have the newest Imac and working in rgb, what can be reason that the new 3d extrude is not available? I've searched all the web but can't find any solution.. This is my system info:
                                  Adobe Photoshop Version: 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00) x64
                                  Operating System: Mac OS 10.8.2
                                  System architecture: Intel CPU Family:6, Model:58, Stepping:9 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2
                                  Processor speed: 3200 MHz
                                  Built-in memory: 8192 MB
                                  Free memory: 4325 MB
                                  Memory available to Photoshop: 6918 MB
                                  Memory used by Photoshop: 70 %
                                  Image tile size: 1024K
                                  OpenGL Version: 2.1 NVIDIA-8.6.22
                                  OpenCL Version:
                                  Video Card Renderer: NVIDIA GeForce GTX 675MX OpenGL Engine
                                  Display: 1
                                  Main Display
                                  Display Depth:= 32
                                  Display Bounds:=  top: 0, left: 0, bottom: 1440, right: 2560
                                  Video Renderer ID: 16918084
                                  Video Card Memory: 999 MB
                                  Serial number: 92629708852858167947
                                  Application folder: Macintosh HD:Applications:Adobe Photoshop CS6:
                                  Scratch volume(s):
                                    Macintosh HD, 973,2G, 720,3G free
                                  Required Plug-ins folder: Macintosh HD:Applications:Adobe Photoshop CS6:Adobe Photoshop CS6.app:Contents:Required:
                                  Primary Plug-ins folder: Macintosh HD:Applications:Adobe Photoshop CS6:Plug-ins:
                                     adbeape.framework   adbeape   3.3.8.19346   66.1025012
                                     AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.2.29.18602   66.490082
                                     adobe_caps.framework   adobe_caps   6.0.29.0   1.276181
                                     AdobeACE.framework   AdobeACE   2.19.18.20743   66.507768
                                     AdobeAGM.framework   AdobeAGM   4.26.20.20743   66.507768
                                     AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
                                     AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
                                     AdobeBIB.framework   AdobeBIB   1.2.02.20743   66.507768
                                     AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   66.507768
                                     AdobeCoolType.framework   AdobeCoolType   5.10.33.20743   66.507768
                                     AdobeCrashReporter.framework   AdobeCrashReporter   6.0.20120720
                                     AdobeExtendScript.framework   AdobeExtendScript   4.2.12.18602   66.490082
                                     AdobeJP2K.framework   AdobeJP2K   2.0.0.18562   66.236923
                                     AdobeLinguistic.framework      17206
                                     AdobeMPS.framework   AdobeMPS   5.8.0.19463   66.495174
                                     AdobeOwl.framework   AdobeOwl   4.0.95   66.510504
                                     AdobePDFL.framework   AdobePDFL   10.0.1.18562   66.419471
                                     AdobePDFSettings.framework   AdobePDFSettings   1.4
                                     AdobePIP.framework   AdobePIP   6.0.0.1654
                                     AdobeScCore.framework   AdobeScCore   4.2.12.18602   66.490082
                                     AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
                                     AdobeXMP.framework   AdobeXMPCore   66.145661   66.145661
                                     AdobeXMPFiles.framework   AdobeXMPFiles   66.145661   66.145661
                                     AdobeXMPScript.framework   AdobeXMPScript   66.145661   66.145661
                                     ahclient.framework   ahclient   1.7.0.56
                                     aif_core.framework   AdobeAIF   3.0.00   62.490293
                                     aif_ocl.framework   AdobeAIF   3.0.00   62.490293
                                     aif_ogl.framework   AdobeAIF   3.0.00   62.490293
                                     AlignmentLib.framework   xcode   1.0.0.1
                                     amtlib.framework   amtlib   6.0.0.75
                                     boost_date_time.framework   boost_date_time   6.0.0.0
                                     boost_signals.framework   boost_signals   6.0.0.0
                                     boost_system.framework   boost_system   6.0.0.0
                                     boost_threads.framework   boost_threads   6.0.0.0
                                     Cg.framework   NVIDIA Cg
                                     CIT.framework   CIT   2.0.5.19287   145486
                                     data_flow.framework   AdobeAIF   3.0.00   62.490293
                                     dvaaudiodevice.framework   dvaaudiodevice   6.0.0.0
                                     dvacore.framework   dvacore   6.0.0.0
                                     dvamarshal.framework   dvamarshal   6.0.0.0
                                     dvamediatypes.framework   dvamediatypes   6.0.0.0
                                     dvaplayer.framework   dvaplayer   6.0.0.0
                                     dvatransport.framework   dvatransport   6.0.0.0
                                     dvaunittesting.framework   dvaunittesting   6.0.0.0
                                     dynamiclink.framework   dynamiclink   6.0.0.0
                                     FileInfo.framework   FileInfo   66.145433   66.145433
                                     filter_graph.framework   AdobeAIF   3.0.00   62.490293
                                     hydra_filters.framework   AdobeAIF   3.0.00   62.490293
                                     ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
                                     ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
                                     image_compiler.framework   AdobeAIF   3.0.00   62.490293
                                     image_flow.framework   AdobeAIF   3.0.00   62.490293
                                     image_runtime.framework   AdobeAIF   3.0.00   62.490293
                                     LogSession.framework   LogSession   2.1.2.1652
                                     mediacoreif.framework   mediacoreif   6.0.0.0
                                     PlugPlug.framework   PlugPlug   3.0.0.383
                                     UpdaterNotifications.framework   UpdaterNotifications   6.0.0.24   "6.0.0.24"
                                     wrservices.framework
                                  Required plug-ins:
                                     Accented Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Adaptive Wide Angle 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
                                     ADM 3.10x16, Copyright © 1987-2008 Adobe Systems Inc.  All rights reserved. - from the file “AdobeADM.bundle”
                                     Angled Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Average 13.0.1 20120808.r.519 2012/08/08:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Average.plugin”
                                     Bas Relief 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Camera Raw 7.0 (308), Copyright © 2012 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
                                     Chalk & Charcoal 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Chrome 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Cineon 13.0.1 20120808.r.519 2012/08/08:21:00:00  ©2002-2012 Adobe Systems Incorporated - from the file “Cineon.plugin”
                                     Clouds 13.0.1 20120808.r.519 2012/08/08:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
                                     Collada DAE 13.0.1 20120808.r.519 2012/08/08:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
                                     Color Halftone 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Colored Pencil 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Conté Crayon 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Craquelure 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Crop and Straighten Photos 13.0.1 20120808.r.519 2012/08/08:21:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
                                     Crop and Straighten Photos Filter 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Crosshatch 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Crystallize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Cutout 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Dark Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     De-Interlace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Difference Clouds 13.0.1 20120808.r.519 2012/08/08:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
                                     Diffuse Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Displace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Dry Brush 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Eazel Acquire 13.0.1 20120808.r.519 2012/08/08:21:00:00  ©1997-2012 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
                                     Embed Watermark NO VERSION - from the file “DigiSign.plugin”
                                     Enable Async I/O 13.0.1 20120808.r.519 2012/08/08:21:00:00  © 2004-2012 Adobe Systems Incorporated - from the file “Enable Async IO.plugin”
                                     Extrude 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     FastCore Routines 13.0.1 20120808.r.519 2012/08/08:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “FastCore.plugin”
                                     Fibers 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Film Grain 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Filter Gallery 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Fresco 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Glowing Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Graphic Pen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Halftone Pattern 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     HDRMergeUI 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
                                     IFF Format 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Ink Outlines 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     JPEG 2000 13.0.1 20120808.r.519 2012/08/08:21:00:00  ©2001-2012 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
                                     Lens Blur 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
                                     Lens Correction 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
                                     Lens Flare 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Liquify 13.0, Copyright © 2001-2012 Adobe Systems Incorporated - from the file “Liquify.plugin”
                                     Matlab Operation 13.0.1 20120808.r.519 2012/08/08:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                                     Measurement Core 13.0.1 20120808.r.519 2012/08/08:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
                                     Mezzotint 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     MMXCore Routines 13.0.1 20120808.r.519 2012/08/08:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “MMXCore.plugin”
                                     Mosaic Tiles 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Multiprocessor Support 13.0.1 20120808.r.519 2012/08/08:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
                                     Neon Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Note Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     NTSC Colors 13.0.1 20120808.r.519 2012/08/08:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
                                     Ocean Ripple 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Oil Paint 13.0, Copyright © 2011 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
                                     OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Paint Daubs 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Palette Knife 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Patchwork 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Paths to Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     PCX 13.0.1 20120808.r.519 2012/08/08:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PCX.plugin”
                                     Photocopy 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Photoshop 3D Engine 13.0.1 20120808.r.519 2012/08/08:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
                                     Picture Package Filter 13.0.1 20120808.r.519 2012/08/08:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
                                     Pinch 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Pixar 13.0.1 20120808.r.519 2012/08/08:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “Pixar.plugin”
                                     Plaster 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Plastic Wrap 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Pointillize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Polar Coordinates 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Portable Bit Map 13.0.1 20120808.r.519 2012/08/08:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PBM.plugin”
                                     Poster Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Radial Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Radiance 13.0.1 20120808.r.519 2012/08/08:21:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “Radiance.plugin”
                                     Read Watermark NO VERSION - from the file “DigiRead.plugin”
                                     Reticulation 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Ripple 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Rough Pastels 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Save for Web 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - from the file “Save for Web.plugin”
                                     ScriptingSupport 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
                                     Shear 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Smart Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Smudge Stick 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Solarize 13.0.1 20120808.r.519 2012/08/08:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Solarize.plugin”
                                     Spatter 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Spherize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Sponge 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Sprayed Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Stained Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Stamp 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Sumi-e 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Targa 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Texturizer 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Tiles 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Torn Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Twirl 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Underpainting 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Vanishing Point 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
                                     Water Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Watercolor 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
                                     Wave 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Wind 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                     Wireless Bitmap 13.0.1 20120808.r.519 2012/08/08:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “WBMP.plugin”
                                     ZigZag 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
                                  Flash:
                                     Mini Bridge
                                     Kuler
                                  • 14. Re: Photoshop CS6 3D menu grey out
                                    Curt Y Level 7
                                    Try updating your version.  Believe you should be on 13.0.4 or 13.1.2 if on cloud/subscription.
                                    • 15. Re: Photoshop CS6 3D menu grey out
                                      Really thanks. I have solved this problem!!!
