1. Re: Rubberbanding Audio: How To?
jstrawn Jun 18, 2012 2:22 PM (in response to conleec)It sounds like you're doing the right thing, but let's try to make it a little clearer:
1) Drag and drop a clip with audio into the timeline
2) Twirl open the audio track header
3) Move the Current Time Indicator over the clip, wherever you want the first keyframe to be
4) Press the 'Add-Remove Keyframe' button
Did that work? Are you zoomed to a level where you can see that part of the clip with decent detail?
2. Re: Rubberbanding Audio: How To?
conleec Jun 18, 2012 2:57 PM (in response to jstrawn)It does not work. I just stepped into the other room and tried it on another editor's machine running CS 5.5 and it worked as you describe. That editor came in my room and agreed, it's not working in CS6. I don't even see the audio level line.
However, I can see the track based audio level indicator and I can add and subtract keyframes from that. Am I in a mode that I shouldn't be? I'd rather be working with clip based gain for this project.
I've tried the "show clip" keyframes vs "show timeline" keyframes (or words to that effect) and they don't seem to make a difference.
The other editor DID show me that I can make and edit keyframes in the Effect Control panel, which is a serious cludge, but it's a workaround.
For what it's worth I'm cutting 5K Red Epic footage natively with merged clips, as all my audio came from a field recorder. Could that be what's glitching?
Chris Conlee
3. Re: Rubberbanding Audio: How To?
Hindsight_Productions Jun 18, 2012 3:02 PM (in response to conleec)How about a screen shot so we can see your timeline?
4. Re: Rubberbanding Audio: How To?
conleec Jun 18, 2012 3:06 PM (in response to Hindsight_Productions) -
5. Re: Rubberbanding Audio: How To?
Bill Hunt Jun 18, 2012 3:27 PM (in response to conleec)Chris,
I might be missing it, but is your Audio Track Targeted?
If not, when you Target it, you should be able to Add Keyframe.
6. Re: Rubberbanding Audio: How To?
jstrawn Jun 18, 2012 3:28 PM (in response to conleec)For what it's worth I'm cutting 5K Red Epic footage natively with merged clips, as all my audio came from a field recorder. Could that be what's glitching?
Probably. I just imported a 4k r3d clip with 4 merged audio tracks and I did find that the keyframe header controls were getting greyed out when I scrolled those tracks out of view and back in. The workaround for that was just to re-select any one of those audio clips in the timeline.
But I also found that if I dragged the 4k clip into a sequence that was not especially build for it (the auido setting are different) then I was not getting the keyframe options in the timeline at all. The workwaround for that was to drag the clip right over the 'New' item' icon in the project panel, which forces it to creat a new sequence that matches that clip.
It looks like there's bug of some sort going on here. I'll look into it, and if there's not already an open report for it, I will log it myself. THANK YOU very much for your support.
-James
7. Re: Rubberbanding Audio: How To?
conleec Jun 18, 2012 4:00 PM (in response to jstrawn)@jstrawn:
You said "The workwaround for that was to drag the clip right over the 'New' item' icon in the project panel, which forces it to create a new sequence that matches that clip."
I tried this with a clip and it created a new sequence but it still didn't work. In addition, as soon as I turn down the audio track arrow, the timeline ceases to redraw correctly. If I scroll the timeline either left or right, the whole thing qoes perquacky. See attached image...
That's supposed to be one single merged clip with video and one audio track of roughly equal duration. But when I scrolled the timeline, the audio "ghosts" for lack of a better word. This has been discussed in the following thread as well.
http://forums.adobe.com/thread/1002143?tstart=0
Chris Conlee
Mac Pro (4,1)
OS X 10.7.4
24Gb RAM
nVidia GTX 285 (CUDA 4.2.10)
Dual Monitors
Matrox Mini Max
PP 6.0.1
8. Re: Rubberbanding Audio: How To?
jstrawn Jun 18, 2012 4:58 PM (in response to conleec)I'm investigating the problem from my end, and I have encountered 'frozen' clips like what you're seeing, but the repro is not that relaible for me yet and I haven't found a sure-fired workaround. I'll update when I know more.
9. Re: Rubberbanding Audio: How To?
conleec Jun 18, 2012 5:06 PM (in response to jstrawn)Hmmm, it's reliable as clockwork here. If I turn down the audio arrow and scroll the timeline, it screws up, no ifs, ands, or buts about it. Thanks for the followup, though.
Chris Conlee
Mac Pro (4,1)
OS X 10.7.4
24Gb RAM
Dual Monitors
Matrox Mini Max
PP 6.0.1
10. Re: Rubberbanding Audio: How To?
conleec Jun 20, 2012 10:50 AM (in response to jstrawn)Just a followup. I had a bright idea and created a new sequence by dragging one of my Epic clips directly to the "new sequence" button on the bottom of the project window. I confirmed that this clip would then allow me to add and manipulate audio keyframes: it did, exactly as expected.
Then I copied and pasted my merged clips from my other sequence into the new sequence, thinking it might propogate the ability to rubber band my audio...but, no love. I can still rubberband my audio from the camera original audio, but as you can see from the attached image, the merged clips still lack an audio level indicator and you cannot add visible keyframes to the clips.
Also, as discussed in this thread -- http://forums.adobe.com/message/4502408#4502408
The timeline immediately begins having redraw issues when the audio arrows are turned down with the merged clips in the timeline. No such problems prior to adding the merged clips to the timeline.
I'd be happy to ZIP up and email my project file to anybody at Adobe who might find it useful in tracking down this issue.
Chris Conlee
Mac Pro (4,1)
OS X 10.7.4
24Gb RAM
Dual Monitors
Matrox Mini Max
PP 6.0.1
11. Re: Rubberbanding Audio: How To?
jstrawn Jun 20, 2012 11:55 AM (in response to conleec)The timeline immediately begins having redraw issues when the audio arrows are turned down with the merged clips in the timeline. No such problems prior to adding the merged clips to the timeline.
Much appreciated, but that won't be necessary. That was one of the problems I saw when I first looked into your issues and there is already an open bug on it.
12. Re: Rubberbanding Audio: How To?
conleec Jun 20, 2012 1:13 PM (in response to jstrawn)@JSrawn: Thanks for the followup.
Chris Conlee
Mac Pro (4,1)
OS X 10.7.4
24Gb RAM
Dual Monitors
Matrox Mini Max
PP 6.0.1
