1. Re: Thousands of RGB Equations
Bill@VT Jun 20, 2012 7:20 AM (in response to 1106design)What is the form of the export? Since this is the Acrobat forum, I assume they are PDFs.
2. Re: Thousands of RGB Equations
1106design Jun 20, 2012 9:07 AM (in response to Bill@VT)Yes, I was wondering if there's a way to convert the PDFx file to all CMYK black, rather than open thousands of equations in Illustrator. :-) And if it is possible, what settings to use, as there are so many.
3. Re: Thousands of RGB Equations
Dave Merchant Jun 20, 2012 9:48 AM (in response to 1106design)If you're using InDesign then simply export it with a color conversion profile applied - no need to fix it later in Acrobat. For example if you have a print intent, export to PDF/X-1a and everything will convert to CMYK since that standard won't allow anything else. If you need a different PDF setup to retain interactive stuff etc., select Convert to Profile in the PDF export dialog under the Output tab, and pick something like SWOP2.
4. Re: Thousands of RGB Equations
1106design Jun 20, 2012 9:54 AM (in response to Dave Merchant)Terrific, thanks!
