1. Re: Playback loops to beginning: How to stop?
John T Smith Jun 18, 2012 5:28 PM (in response to conleec)See if this helps...
Playback Loops or Stops http://kb2.adobe.com/cps/842/cpsid_84287.html
2. Re: Playback loops to beginning: How to stop?
Bill Hunt Jun 18, 2012 6:34 PM (in response to conleec)Chris,
Is this happening, with zero input from you?
The reason that I ask is that many users have tried to hit the Spacebar, to Stop playback, but are a tad late, and then the Spacebar begins playing from 00;00;00;00.
3. Re: Playback loops to beginning: How to stop?
conleec Jun 18, 2012 7:02 PM (in response to Bill Hunt)Bill,
That is EXACTLY what I'm doing. Coming from Avid it's second nature, and it's killing me. I'm trying desperately to train myself not to hit the spacebar.
Chris Conlee
4. Re: Playback loops to beginning: How to stop?
Kevin-Monahan Jun 18, 2012 7:51 PM (in response to conleec)Do you have the Loop button enabled?
5. Re: Playback loops to beginning: How to stop?
conleec Jun 18, 2012 10:22 PM (in response to Kevin-Monahan)I'm not sure. Where do I check if it's in loop mode? And if I take it out of loop mode, can I then hit the spacebar without it starting from the beginning of the timeline again? That behavior is annoying me coming from another package.
Chris Conlee
6. Re: Playback loops to beginning: How to stop?
Averdahl Jun 19, 2012 3:42 AM (in response to conleec)Chris,
It sounds that this Preference setting needs to be disabled: "Playback work area after rendering previews".
1. Premiere Pro > Preferences > General
2. Uncheck "Playback work area after rendering previews"
3. Click on OK
This is the first Preference i change beacuase of this "sometimes-jump-back-to-start-behaviour". Maybe that's the solution for you, maybe not. Try it and see if it helps.
/Roger
7. Re: Playback loops to beginning: How to stop?
Jerry Klaimon Jun 19, 2012 7:13 AM (in response to conleec) -
8. Re: Playback loops to beginning: How to stop?
pmw_film Oct 31, 2012 3:25 PM (in response to Averdahl)thanks! it worked for me
