1 Reply Latest reply on Jun 19, 2012 10:05 AM by Mylenium
    Installing CS6 Errors
    jack502003
      I've been trying to install the CS6 Creative Suite(Acrobat, Photoshop & Illustrator) for a while now and I keep getting a list of errors at the end. This is my error summary:
      Exit Code: 6
      Please see specific errors and warnings below for troubleshooting. For example, ERROR: DF023, DW063 ... WARNING: DW024, DW065 ...
      -------------------------------------- Summary --------------------------------------
      - 0 fatal error(s), 10 error(s), 3 warning(s)
      WARNING: DW024: The payload: {9124DF4E-617D-486B-A970-8FA632244F24} Adobe Photoshop CS6 Core 13.0.0.0 requires a UI parent with following specification:
      Family: Photoshop
      ProductName: Adobe Photoshop CS6 Core_x64
      This parent relationship is not satisfied, because this payload is not present in this session.
      WARNING: DW065: Display requirements not met for {E8AD3069-9EB7-4BA8-8BFE-83F4E69355C0} CS6 Master Collection 6.0.0.0
      WARNING: DW065: Display requirements not met for {7D4E9D10-AED6-485D-A2B0-9A1DF1A55545} Adobe Illustrator CS6 Core 16.0.0.0
      ----------- Payload: {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 1.0.0.0 -----------
      ERROR: Install MSI payload failed with error: 1612 - 這個產品的安裝來源無法使用。請確認來源是否存在及您可以存取來源。
      MSI Error message:
      ----------- Payload: {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0 -----------
      ERROR: DF023: Unable to delete backup file at "C:\adobeTemp\backup\adobetmp294527375" Error 5 存取被拒。(Seq 38)
      ERROR: DW063: Error committing command ARKDeleteFileCommand(Seq 38)
      ----------- Payload: {AC76BA86-1033-F400-7760-000000000005} Acrobat Professional 10.0.0.0 -----------
      ERROR: Error 1324.The path R嶰up廨er un document num廨is?sur un multifonction.sequ or the volume is invalid. Please enter it again.
      ERROR: Install MSI payload failed with error: 1603 - 安裝時發生嚴重錯誤。
      MSI Error message: Error 1324.The path R嶰up廨er un document num廨is?sur un multifonction.sequ or the volume is invalid. Please enter it again.
      ERROR: DW050: The following payload errors were found during install:
      ERROR: DW050: - Microsoft_VC90_CRT_x86: Install failed
      ERROR: DW050: - Microsoft_VC80_CRT_x86: Install failed
      ERROR: DW050: - Acrobat Professional: Install failed
      ERROR: DW050: - Adobe Mini Bridge CS6: Install failed
      ERROR: DW050: - Adobe SwitchBoard 2.0: Install failed
      I'm using Windows 7 SP1; Hardware : Intel Xeon 31230, 8GB Ram, 2TB H.D.
      Thank you in advance for your help.
        • 1. Re: Installing CS6 Errors
          It means what it says - display requirements not met. Either the screens ar really too small or misconfigured. And yes, that Chines directory names may also figure in, but I can't help you with that. Try to set your system to English.
          Mylenium
