1. Re: Best way to export HD to DVD
Harm Millaard Jun 19, 2012 9:39 AM (in response to frogmike)MPEG2-DVD.
2. Re: Best way to export HD to DVD
JSS1138 Jun 20, 2012 7:50 PM (in response to Harm Millaard)Also, use the Scale to Fill option on the Output tab of the Export Settings.
3. Re: Best way to export HD to DVD
Axel Matt Jun 21, 2012 12:51 AM (in response to frogmike)Open your project via Dynamic Link in Adobe's Encore. In Encore you can create a DVD project with menues and so on and you can it directly burn it on a DVD.
4. Re: Best way to export HD to DVD
srukweza Jun 21, 2012 2:04 AM (in response to frogmike)In Premiere Pro go to file/ Adobe Dynamic Link/Send to Encore. Your sequence will launch Encore automatically. In Encore right click your sequence to set your transcode sttings and check the MRQ box for excellent HD to SD results.
Hope this helps.
5. Re: Best way to export HD to DVD
JSS1138 Jun 21, 2012 7:36 AM (in response to srukweza)I don't believe the Dynamic Link option will allow for the required Pan & Scan. It'll come out letterboxed or anamorphic.
6. Re: Best way to export HD to DVD
Stan Jones Jun 21, 2012 9:11 AM (in response to JSS1138)Encore does have crop and scale to fit, in the Edit Quality Presets, so you could probably make it work.
I have not played with CS6 enough, but the verdict is still out on whether you want to let Encore (as Encore or AME) transcode HD to SD, rather than using PR/AME.
