3 Replies Latest reply on Jun 19, 2012 11:21 PM by Mylenium
    populate videos in a circle
    kimtrager
      Hey
      I have a bit of a question, I've done som images in Illustrator (see picture below), which im now trying to do with moving images in after effects.
      I've go a bit of green screen footage, keyed out the background, and chopped of anything unwanted.
      For making these pictures in Illustrator it's quite easy you just have 2 mirrored pictures opposite each other, with both marked you go to rotate, tell illustrator how much you want the picture to rotate and then say "copy". Is there any way to do the same in After effects, with video footage?
        • 1. Re: populate videos in a circle
          Dan Fredley Level 1
          Here's a guy who is good at duplication:
          http://youtu.be/GAvS1ndtEKg
          But on the serious side, you can only do it with vector shape layers in any sort of automated way.
          But with expressions you could set up a composition to calculate the necessary angle rotations as you duplicate the layer:
          With only the layer that you want to duplicate in the comp, put this expression on the rotation value:
          index*360/thisComp.numLayers
          Duplicate it once then put this expression on each anchorPoint value except the top one which you will change to adjust the radius of the circle:
          thisComp.layer(index-1).anchorPoint
          Then duplicate as many times as you would like and adjust the anchorPoint of the top layer.
          Using this method you'll have to create different compositions for each ring of pictures you want to make since the expression is dependent on then number of layers in the comp.
          • 2. Re: populate videos in a circle
            Andrew Yoole MVP & Adobe Community Professional
            Depending on how much control you need, you might want to play with CC Kaleida as a simple alternative.  Multiple kaleidoscopic layers can produce amazingly complex patterns.
            • 3. Re: populate videos in a circle
              As Andrew said, CC Kaleida and other tiling tools (including AE's own Mirror and Motion Tile) will give you plenty to work with. And then there's also things like Card dance, Trapcode form or Trapcode Echospace that can repeat particles or 3D layers and create patterns in a multitude of ways....
              Mylenium
